The drivetrain
The Cross Coupé quattro is powered by an all-new 2.0 TDI diesel engine, the first example of the new generation of four-cylinder TDI engines in the Volkswagen/Audi Group. This 150 kW (204 bhp) power plant marries distinctly sporty characteristics – peak torque is 400 Nm between 2,000 and 3,500 rpm – with a high level of refinement and an impressive degree of economy and efficiency. The compact yet powerful sports car needs just 5.9 litres of diesel for 100 km.
The fuel/air mixture is prepared by a common-rail system of the latest generation, which is also employed by Audi in the V6 TDI engines. It has a high-pressure pump and common manifold (rail) for each of the four cylinders. The maximum injection pressure is 2,000 bar.
The high injection pressure provides for even finer atomisation of the fuel and thus for a better mixture and more efficient combustion. Piezo injectors allow the number of injection sequences per working cycle to be varied almost at will. A strategy that provides for both softer combustion and for lower untreated emissions – in other words, top engine acoustics and at the same time extremely low overall emissions. Without doubt, the 2.0 TDI engine is the current benchmark in its class in both disciplines.
More innovative technology on board reduces overall emission even further. For example, the new engine is not only combined with a diesel particulate filter, but also employs the Bluetec injection system to reduce nitric oxides effectively.
The heart of the Bluetec technology is a special catalytic converter downstream of the oxidising catalyst and the particulate filter.
The second component in the system is an additional tank containing a watery solution of carbamide (urea). Small quantities of the solution, known as "AdBlue", are injected into the exhaust system. The hot exhaust gases break the solution down to form ammonia, which splits the nitric oxides into nitrogen and water. The system will remain effective for the entire service life of the vehicle.
With such extremely clean Bluetec diesel engines, Audi is continuing its tradition of leading from the front in matters of diesel engine technology. In 1989 it was the Ingolstadt brand that developed direct injection technology. Since then the diesel engine has become around 30 percent more economical and the Euro 4 European emission standard has reduced particulate emissions by 93 percent. Long before it came into force, Audi had models on the market that satisfied this standard, even without a particulate filter.
This equipment enables the Audi Cross Coupé quattro even today to meet the most stringent regulations currently known, the Euro 6 standard and the strict US emissions legislation.
The quattro permanent four-wheel drive system provides for power transmission – what else would you expect from an Audi with a powerful engine and offroad qualities? An electronically controlled viscous clutch provides variable power distribution between the front and rear wheels, just as it does on the Audi A3 quattro and the Audi TT.
The sporty Audi S tronic direct-shift gearbox enables the driver to execute a gear change within a fraction of a second without a clutch pedal. If he wants, the gearbox will make all gear changes fully automatically. And if he wants to change gear manually, he can do this with the shift paddles in the steering wheel. The newly designed selector lever with integrated control knob for selecting gear is a further development of the shift-by-wire system.
The running gear
The second pillar on which the excellent driving dynamics are built is the elaborate running gear, with McPherson-strut front axle and four-link independent-suspension rear axle. Large 20" wheels with size 245/45 R20 tyres also contribute to driving fun and safety.
The dynamic suspension is designed to give sporty, agile handling and a high degree of stability while making cornering distinctly fun. As an additional quality, the running gear impresses with a driving comfort that would satisfy the standards expected in higher vehicle classes.
The capability of the engine is matched by the potential of the brake system with its large-diameter discs.
The electromechanical steering system with speed-dependent power steering provides for superlative handling. It combines optimum steering feel with low sensitivity to agitation from the road surface and significantly reduced power consumption.
The special qualities of the four-link axle are based on the functional separation of the longitudinal and lateral force absorption points. On the one hand, this allows a high degree of lateral rigidity, which favours superior dynamics and driving safety. On the other hand it also allows a high degree of longitudinal suppleness, improving ride comfort.
Individual springs and shock absorbers provide vertical support. The shock absorbers are located close to the wheels, allowing a very large load width in the luggage compartment. A tubular transverse stabiliser is secured to the subframe with highly rigid bonded-metal rubber mounts. This effectively reduces the body's tendency to roll and thus positively influences the transmittable lateral forces – ultimately improving the vehicle's handling.
The shock absorbers employ the Audi magnetic ride system, an innovative technology that has already impressed in the Audi R8 high-performance sports car and in the TT. Instead of conventional shock absorber oil, a magneto-rheological fluid is used, a fluid whose viscosity is influenced by an electromagnetic field. This effect means that the shock absorber map can be changed at any time simply by applying a voltage to the solenoids.
Audi magnetic ride exploits this property to ensure that the correct shock absorber force is available in all driving situations and thus optimising ride comfort and driving dynamics. A computer equipped with sensor technology determines the prevailing driving situation in a matter of milliseconds. Here, the driver can choose between two driving programs, depending on whether he wants to drive with a sportier style – requiring low viscosity of the magneto-rheological fluid – or with a greater emphasis on ride comfort.
Excellent performance, low weight and maximum mileage are offered by the ceramic brakes. Here, the discs are produced from a ceramic material reinforced with carbon fibres – a combination that has long been proven in the aviation industry.
It only takes a glance to see the ceramic discs against the anthracite grey paint of the special aluminium callipers. The advantage of ceramic brakes over steel discs is the weight saving of some 20 kg, which improves drivability and comfort. The high level of resistance to abrasion allows a service life of up to 300,000 km. However, its most important strength is its lack of sensitivity to extreme loads.
Audi drive select
Only a small minority of motorists can afford the luxury of having three cars in their garage, one each for their changing needs: comfort, agility or dynamic driving. There is however a single car which satisfies all three of these: the Audi Cross Coupé quattro.
Audi drive select makes it possible to preselect three highly individual configurations for the engine, gearbox and the magnetic ride shock absorbers. The result: a car that can be enjoyed in three completely different ways and that offers a huge potential in the field of efficiency.
The basic setting is "dynamic" mode. This is automatically activated every time the engine is started and generally meets the expectations that Audi drivers have of their car with respect to the dynamic yet comfortable driving feel that is typical of the brand.
"Sport" mode on the other hand gives the Cross Coupé an emphatically sporty feel. The shock absorbers have a firmer setting, the engine responds more spontaneously and the S tronic gearbox moves its shift points to a higher rpm range. Ideal conditions for active driving pleasure on winding roads.
Then again, if the driver selects "efficiency" mode on the MMI, the engine and S tronic gearbox respond more gently to commands from the accelerator pedal and shift paddles. This setting is perfectly suited to relaxed driving and at the same time opens up huge potential for effectively reducing fuel consumption and thus emissions. In efficiency mode, the air-conditioning system is switched off and is only reactivated if the driver so wishes. A completely new interpretation of the cruise control system also moves the vehicle with minimum fuel consumption, allowing the set speed to drop to a certain lower limit in favour of lower fuel consumption, for example on moderate uphill stretches on the motorway.
Efficiency mode also makes use of route data from the navigation system and reduces speed early to make driving as economical as possible by avoiding the need for heavy braking when approaching a tight bend or (in conjunction with adaptive cruise control) a vehicle driving ahead.
In this way, under normal operating conditions and combined with a forward-looking driving style, Audi drive select makes it possible to make fuel savings of more than 20 percent compared to dynamic mode.
source Audi & http://www.fourtitude.com/news/publi...cle_3077.shtml
- Ben
1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
2008 Jetta 2.0L FSI
