Page 1 of 3 123 LastLast
Results 1 to 10 of 35
Thread: Work XD9's - 18x9 +30 - 5x100PCD!
    Jun 2009
    ah, yes, but 9"....
    hmmmm
    Dec 2008
    Quote Originally Posted by dainese View Post
    ah, yes, but 9"....
    hmmmm
    Agree- I want them- but will they fit...that is the question? Plus I have not seen any mk4 running 9inch at the front.
    Jun 2009
    Quote Originally Posted by pauld View Post
    nah, me neither. i think at this point - jsut get them.!
    worry about it later.
    run a narrower tyre, roll guards. vortex members, tend to have 8.5 out front. can't be that far off. as long as you don't lower it.
    Mar 2007
    sydney
    i like the way people say "get some balls and buy these" while the guys who say it dont buy jack all for there cars., hot wheels tho/.
    mk4 the mods begin for round 2 hahahha
    Aug 2007
    Camden, NSW
    I put them in the wheel offset calculator and compared to my 17x7.5 et38 bora sports: 11mm less inner clearance behind spokes, 27mm more poke!!! Logic says if they are 32.5mm wider than my 7.5" then they will also be (32.5-27mm) 5.5mm wider on the inside edge as well? So there's all sorts of potential for rubbing...
    03 MkIV GTI - K04-001, APR 2.5" TBE/TIP/Software, Forge FMIC, GFB DV+, Powergasket+, Dark Tint, 17" Bora Sport, Bilstein shocks, Eibach springs, BMC CDA, Dieselgeek SS, Hella Celis, R32 Alloy Trim...
    95 MkIII VR6 (sold)
    8.5 on a spring and shock combo will fill up the front of a MK4. COULD be made to fit with some serious guard rolling though? go get a tape and measure from your shock to the guard.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jun 2009
    yeah, i don't like our chances. tommy's R32 scrubs with 8.5 CH's. its a nice height though (low).
    unless we can shave the offset down - maybe... but a lot of modifying then.
    9" on the front would be pushing it unless you ran camber and stretched tyres i recon
    Id be more worried about the poke/gaurd clearence.
    8" with ET45 clears on standard suspension and JUST touched my coilovers
    so run that through the offset calculator vs the 9" ET30, 2mm more clearence (nice) and 28mm of poke compared to the 8" ET45
    compare the 9" ET30 to 8.5 ET35 (the CHs yes??), 1m less inner and 11mm more outside clearence.
    So i wouldnt be shaving the offset to put it any closer to the strut. Unless the golfs and R32s are that much different to the boras?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    May 2009
    S.E. Melb Vic
    Are they still available?
