I wonder how they'd look on my Golf
I live nearby so maybe I should check them out
eBay Australia: Buy new & used fashion, electronics & home d
Taken from auction:
$300.00 Starting bid
$350.00 Buy it now
16" Volkswagen Polo GTi Wheels (PCD 5x100)
These are in good condition. They do not have any major gutter rash. Only a few minor stone chips.
The tyres that are on two of the wheels are not in roadworthy condition. May be alright as a spare but not much else
Pickup from Berwick (Melbourne).
Thanks.
How come? They're 16" just like my wheels and have the same 5 bolts as mine.
I'd much rather read the correct logic first.![]()
The question is...
Is your golf a mk iv or a mark v?
06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
they might be the same diameter, and have 5 bolts as well, but that doesnt mean that they will fit. the reason for this, is because the diameter of the circle that is formed by your five bolts, is 112mm. you have five bolts, hence your stud (bolt) pattern is 5x112mm.
the polo gti whose wheels are in question, has a pcd of 5x100mm. therefore, they will not fit.
pcd is very important to take into consideration when buying wheels - for example, just because a holden hsv thing has nice looking 19 inch wheels with 5 studs, it does not mean that those wheels will simply bolt onto your hubs - because the pcd will be different.
