Results 1 to 8 of 8
Thread: VW Golf Mk3 Vr6 POLISHED Schrick Inlet Manifold OBD II
    Jan 2007
    QLD, Gold Coast
    Feb 2008
    mOOROOLBARK
    not that im game to buy it but what happens if your motor is obd 1
    Point Cook, Vic
    Quote Originally Posted by mk3pete View Post
    The difference is in the throttle body adaptor. The mounting is a little bit different. Ive heard of people adapting from one to the other but its best to get the right one from the start.
    PERFORMANCE, STYLING AND OEM PRODUCTS FOR YOUR VW
    FOLLOW US ON FACEBOOK
    Sep 2006
    Parkinson / Brisbane
    thats pretty expensive
    Point Cook, Vic
    Quote Originally Posted by KI11Z View Post
    I was thinking the same too.. They can be had second hand pretty cheaply from the US. The UK market is generally more expensive for aftermarket gear.
    Having said that I think to have one professionally polished costs a packet!
    The problem with buying second hand is always going to be if something in the kit isnt working or its not complete then its gonna be hard to source the parts separately other than brand new which is mega $$$
    Townsvegas QLD
    Save your $$ I had a schrick it wasnt work the money and it had to be removed to change the plugs and wires, My buddy had a Euro 2.9 that was damaged so we cut it open to see the differences- If you want more flow open up the under side of your stock 2.8 upper manifold and get to grinding the aluminum channel on the inside and extra aluminum thats beside the channel that comes from the throttle body to the six runners and make it smooth as possible-I bead blasted the inside of mine and then polished it a bit mine then welded the back plate on. Also we port matched the upper and lower manifolds and gasket matched and then powder coated it. Way cheeper than a euro mani or a schrick and it can be done in day with the right tools-just my 2cents
    SLAM.POKE.TUCK.DROP.DOPE!
    Feb 2008
    mOOROOLBARK
    fair enough then i was thinking more towards ecu management or maybe the flow rates are slightly different
