Results 1 to 9 of 9
Thread: USA - 13"x8" 4 x 100 WELD DRAG WHEELS $858 Landed
    S.E Melbourne
    If I had the cash I'd jump on these,
    13x8 estimating +25mm offset from what the listing says.
    Weld Magnum Import Drag Wheels 13x8 4x100 Honda Acura : eBay Motors (item 310115794000 end time May-09-10 17:44:21 PDT)
    It doesn't matter what car you drive.. If you're a complete wanker.. People still won't want to talk to you..
    Jun 2007
    Eastern Suburbs Melbourne
    being Honda wheels I'm not sure they'd be +25..
    although with a 5" backspace, that'd put them at a +12 offset. Maybe they're actually that low, being a drag wheel, but it's odd seeing a honda wheel that low of an offset.
    i like volkswagens
    Nov 2005
    its perfectly normal for hondas to have low offsets on drag wheels, for obvious grip reasons being fwd and pretty much dragging everything behind them..., plus on the drag strip there isnt any law about poke......
    every civic ive seen with slicks have wheels that poke
    Jun 2007
    You make a good point Dom!
    i like volkswagens
    S.E Melbourne
    sorry I thought to calculate the offset it was (back spacing - half the width of the wheel)...guessing that formula is wrong... I did say estimate
    +12 is still workable on a mk1 isn't it?
    Nov 2005
    back spacing is calculated hrom the mounting hup to the inner lip's end, so from the mounting hub, its 5" pushed inside
    so to work out offset, you measure from bead lip to bead lip, half that, that will equal the center of the width, then you work out the ET by how far the mounting hub is compared to the center of the wheel....
    dom
    Jun 2007
    I just use this
    i like volkswagens
    Nov 2005
    Quote Originally Posted by Whubbsie View Post
    i had 8 with ET07, stretched tyres permitting hehe
    S.E Melbourne
    Offset (wheel) - Wikipedia, the free encyclopedia
    okay I'm confused, not the only place that says offset is calculated like the formula I used.
    obviously all depends how the backspacing is measured, if it's to the out side of the wheel it would be wrong, but mount hub to outer bead (which I assumed) would be right. thats how I got +25
    If that is the wrong way it's lucky I never win ebay auctions cos I'd have a ****load of useless wheels laying around
    Found another formula
    [Wheel Width / 2] + [Offset] + 6.35mm = [Backspacing]
    4" + ?? + 1/4"= 5"
    101.6MM + ?? + 6.35MM = 127MM
    107.95 + ?? = 127
    ?? = 127- 107.95
    19.05
    Means ET +19.05
    different again
