Both look like crap to me, a hell of a lot of work to get them in the mood![]()
The air-con isn't hooked up. Looks like there's a complete set up for it though.
The battery is dead. Otherwise it should run just fine. Gear linkages are sloppy as hell, selects all gears though.
The seats are actually in great condition! The covers on there are 'protection', not 'cover-ups'!
Dash is pretty cracked, probably 5/10 condition.
Only serious rust is the bottom of the windscreen surround and the bottom of the right/front door.
(and yes, I checked the floors, underneath the rain tray, radiator support, where the arches meet the firewall etc.)
Oh, the other mag-wheel is in the boot with a flat. Ask me about stuff that I might've forgotten...
Okay, maybe it is beyond salvation. I didn't poke around much because you can see there's a bit of wildlife in there!
Dash is history. Didn't see a lot of major rust, but it's obviously had a dodgy re-spray in it's lifetime, found some bog too. There's also a lot of flora and fauna hiding the usual problem areas for rust!
Not a true swallowtail, but it's got a smoothie bonnet, the cool seats and diagonal doorcards, built 2/76.
Ummmm, ask away.
thks ih8 you are a scholar and a gentleman for posting the pics up, does any of the rust look terminal?, is the rust under the windscreen a difficult repair, or depends on your welding skills or relationship with a panel beater?
B6 Passat Wagon No KESSY
Spot on. I'm led to believe removing the screen and replacing it is quite 'easy', it's not complicated and just requires care and patience.
I wouldn't rate that as terminal, my car has the same and I'm ignoring it for now, at least until i have some cover to be able to leave the screen out of the car for a period of time.
thanks again much appreciated someone needs to rescue a Mk1 and give it some loving!! love the white with the stripes and the gold rims
Thanks champ for getting extra snaps. Gonna hit him up to have look on Friday.
Driving the coal. Low and rattly.
He's a top bloke. I might own them by then!
For the floor mats?
