B U M P K04 turbo kit for MKV!!
PRICE DROP! $1400 FOR EVERYTHING! I NEED THESE ALL GONE PLEASE!
Guys,
After buying this kit for my car I was going to upgrade to a stage 2+ tune for my car. However, since my car is almost reaching the second stage of its life (200,000kms), I was told that the bottom end internals would be too weak to support the new power. To safely have the kit operating I would have needed an engine rebuild with new piston rings, vrs kit, conrods,etc. I just simply couldn't finance the project.
I bought the kit from Andrew (W.A.), which had only been on his car for 6000kms before he upgraded to stage 3. As you can see from the meticulous photos, all the parts are in pristine condition. I have most of the parts for the bolt on upgrade but the new owner will have to replace the cam follower, hpfp (if not upgraded), injector & inlet manifold seals, downpipe and a oil line hose for the turbo. The other hoses for the turbo I have them all.
With a giac tune, I was told by Lucas to upgrade my intake, fp and ehaust to make the 2+ tune possible. APR supposedly allows you to keep the oem look, with a high flow air filter insert.
Here is what's included. Sorry if I've missed anything, more details can be discuss via purchase.
- K04 turbo
- S3 injectors
- S3 cooler
- DV re-locator
- Downpipe (curved section only) and exhaust mounting hardware
- Turbo oil lines
- Intercooler hoses
I've also got forge spacers, dv spacer, genuine vw dsg oil (6 litres/bottles), vw coolant 1 bottle and a few other nifty things. I'll throw them all in!
Peeps you can view the photos on ebay: http://www.ebay.com.au/itm/320857899...#ht_500wt_1156
Tony (0421 350 428 )
Bump!!!!
if you get desperate, shoot me an offer?
'07 | MKV GTi RS | COUPE | GIAC | HPFP | EVOMS V-FLOW | TBE | FORGE TWINTER-COOLER | BSH CCC
you can have everything for 1300. I'll throw in top of all that, some forge wheel spaces less than 2000kms of use, and a forge dv spacer as well. all parts are pretty much brand new.
B u m p
