Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: ECS Tuning Magnetic Oil Sump Plugs
  1. #21
    Adelaide hills, SA
    It's a rare earth magnet. They stick like poo on your shoe.
    Also, there's this weird thing called filter paper that the particles have to get through before you get to the oil pump.
    I used to deal with full iron engines all the time. Many of them came standard with a magnet in the sump plug - they didn't have a lot on them after the 3rd service at 10,000km so unless you fit the magnet from day1 (or the engine is self-destructing) then the magnet (no matter where it's fitted) doesn't achieve much.
    What happens when the oil filter is in bypass?
    Here you go Brad, this will explain it to you.
    Oh, and I've seen the magnets tied up to a plastic oil filter caps, too.
  2. #22
    Erskineville, NSW
    Many engines incl. TSI engines have the oil filter cap made from this weird think called plastic.
    Hmm? Didn't have a lot on them, doesn't mean that after the first 10,000km engines stop wearing down.
    Obviously if the oil filter housing was made of plastic then the magnet wouldn't stick to it and therefore trying to make a magnet stay there would be a pointless excercise. One would seek an alternative method.
    No, you are right, it doesn't mean the engine stopped wearing at 10,000km and I didn't suggest that was the case but 95% of the iron filings come out in the first 10,000km (which back then would be an oil change at 1,000km; 5000km & 10,000km). After that it was pretty quiet.
    If the oil filter is in bipass then it's probably blocked, which means it's been on there too long anyway & you probably aren't that concerned about a few particles going through the engine.
    If you don't agree with me, fair enough, you've stated your case. I was offering some alternatives to another forum member. I did not state that an ECS magnetic sump plug was a bad idea - I just said there were other options.
  3. #23
    Nov 2008
    Canberra
    I've had ECS magnetic sump and gearbox drain plugs in from day one. Did the first oil and filter change after driving home from the dealer, then at 5k intervals. Put Redline in the gearbox at 1k.
    For what it's worth, the sump plug has picked up nothing in 5 oil changes, but the gearbox plug definitely has "whiskers" on it after a few thousand ks.
  4. #24
    Adelaide hills, SA
    I have a bit different experience with mine, there are always some iron particles caught on the long magnet body. Maybe because they're much bigger and stronger then other magnetic sump plugs. Also the long shiny surface shows up any early signs of sludge or varnish forming.
    ECS Tuning Magnetic Oil Sump Plugs-sam_9851-jpg
