Results 1 to 3 of 3
Thread: Cheap Polo/MkIV Golf 14" Steelies - VIC
    Oct 2010
    Melbourne, VIC
    vw wheels 5x100 R14 | eBay
    Good for anyone wanting to downsize/smooth ride for their daily drive (hint, hint for Scotty)
    ---------- Post added at 12:23 AM ---------- Previous post was at 12:19 AM ----------
    Also cheapish Polo/MkIV Golf 14" Alloys- NSW
    VW GOLF 14 INCH ALLOY WHEELS | eBay
    Resident grumpy old fart
    melbourne
    hmmmmmmmmmmmmmmmm
    i dont know...
    thing is, they're so cheap!
    but new clutch is here and going in soon, so NVH is going to be down the shtter.
    and 14 inch wheels, no matter how cheap, will just tempt me to put some a048's on them. im hopeless.
    Oct 2010
    Melbourne, VIC
    Get that polyureathane torque arm bush swapped back to stock and also put the stock lower control arm rear bushes changed back to stock from polyureathane - I've found both (well, solid rubber lower control arm rear bushes in my case) make the PoD unpleasant below 1300rpm and VERY unpleasant below 1000rpm.
    I have a solution in the works that will allow these to be easily stiffened when required.
    Fit some reasonable 175/70R14 tyres to the rims and then fit A048Rs to the 15's
