Results 11 to 20 of 30
Thread: 2door swallow project. gumtree tas
    Oakleigh VIC
    Pretty common to replace a nose or tail skin.
    Cut and shut usually implies 2 separate cars cut through the door holes and joined together.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Jun 2007
    Eastern Suburbs Melbourne
    Interested as to why you thought it's a cut and shut.
    No doubt it's had a front end, but that could have been just a crash repair. (how well it was done, always an issue)
    i like volkswagens
    Feb 2009
    Please Enter Location
    Whom is your comment meant for?
    Quote Originally Posted by Stanton View Post
    Sure was Eri, cut and shuts are illegal and have been for many years, it was probably done in the 1980s.
    Not even a good job then.
    I'd say the comment is meant for this person, the only one here who's said not to touch this car because the front is 77 GLS and the rear is early 76 LS.
    Nov 2014
    Passenger floor pan is basically gone, but it isn't that bad a deal, probably $800 in repairs to make right
    If it was VIC/NSW/SA/SE Qld I would probably own it, but Tas transport is harder
    Feb 2009
    How much to redo the join where the 76 back half meets the 77 front half then.
    Oakleigh VIC
    I'm not convinced it's a cut and shut. What makes you so certain?
    Not trying to be rude but I'm just not seeing it from the photos.
    My '76 Golf has a swallow tail front and a later rear but it's not a cut and shut, it's just had the beaver panel replaced due to a rear end accident.
    I've got '90s cabrio front clip repair panel that I'm going to put into a '79 but that won't make it a cut and shut either.
    Also the early Golfs were often a jumble of parts anyway.
    7? MK1 Caddy
    12 Amarok
    Feb 2009
    I give up ! I started by trying to warn off potential buyers from getting caught out but seems no one wants to be saved !
    What a bunch of sad sacks.
    Feb 2014
    all they are asking for, is your reasoning and some proof of your claims, i don't think that warrants calling them 'sad sacks'
    Vento - low on hot tunings
    Feb 2009
    Funny that the car is for sale in Tasmania and the "prove it "comments are from non Tasmanians.
    I don't have to prove anything.
    I suggest a super moderator remove this thread.
