Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 14x8 4x100 14" RCA
    Jun 2007
    Eastern Suburbs Melbourne
    Yea I reckon they're probably a 7" wheel too. don't look nearly wide enough for 8's!
    would make the et32. which means you could fit spacers ont he front to clear brakes (if need be) and not poke a truck load!
    More desirable as 7's imo
    gemini wheels have studs and nuts, just cause they're different. Cb is also like70mm, ours is 57, hence the spacer
    oh and 8's pretty much never fit within the gaurds or a mk 1!
    i like volkswagens
    cool retro as wheels cheap too!!!
    Nov 2005
    its hard to tell with these wheels whether or not you need diff wheel nuts, from what i can tell, they just look like normal ball seats that would suit standard mk1 wheel bolts...
    Jan 2008
    Strathfield,Sydney
    soooo confusing
    76 Scirocco
    Nov 2005
    Hi, the outer width of the rim is 7" and the inner
    (inside tyre bead) is 6". Cheers
    nuf sed, dom
