cool retro as wheelscheap too!!!
Yea I reckon they're probably a 7" wheel too. don't look nearly wide enough for 8's!
would make the et32. which means you could fit spacers ont he front to clear brakes (if need be) and not poke a truck load!
More desirable as 7's imo
gemini wheels have studs and nuts, just cause they're different. Cb is also like70mm, ours is 57, hence the spacer
oh and 8's pretty much never fit within the gaurds or a mk 1!
its hard to tell with these wheels whether or not you need diff wheel nuts, from what i can tell, they just look like normal ball seats that would suit standard mk1 wheel bolts...
soooo confusing![]()
76 Scirocco
nuf sed, domHi, the outer width of the rim is 7" and the inner
(inside tyre bead) is 6". Cheers
