Page 91 of 100 FirstFirst ... 41818990919293 ... LastLast
Results 901 to 910 of 997
Thread: Wreck to Race.
  1. #901
    Boronia VIC
    Parts arrived for the carbs.
    If you're looking for small parts for Dellortos or Webers, EuroCarb in the UK provide an excellent service.
    Dellorto and weber carburettors online
    Only took a week to arrive.
    I got
    1. Longer manifold studs
    2. Soft mounts
    3. Thackery washers
    4. New floats
    5. New genuine needle and seat assemblies
    6. Pump actuator rod nuts.
    7. pack of gaskets
    Today I installed the soft mounts and replaced the floats and needles.
    Longer studs in and loctited in place
    Soft mounts, hopefully these will save the needle and seat from some vibration. Should also prevent heat soak from the manifold.
    I had to order these two nuts in, the origianals rattled loose and fell out on a race track somewhere.
    Non genuine needle and seat on the top and genuine Dellorto unit below.
    Setting up float levels.
    Soft mounts in place and carbs secured with thackery washers under the nylocks.
    All back together again.
    Just waiting on brake pads to arrive from Summit Racing and it'll be right to hit the track again in August.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #902
    Boronia VIC
    Off to the Island tomorrow for the final round of the 2011 Victorian SuperSprint Championships.
    I'm giving the logger and dash I got for my other car a bit of a test drive.
    Here it is temporarily mounted up. I made a rudimentary control panel for it and bolted it to an ashtray I'd already butchered up.
    It'll be interesting to see the data. Still a lot of setting up to do.
    7? MK1 Caddy
    12 Amarok
  3. #903
    Mar 2009
    pete, what's the purpose of soft mounts for the carbs? how do you have enough clearance from the firewall?
    EDIT: just saw the reason, my bad.
    78 2-door 1.8 KR 16v - twin dellorto's
  4. #904
    Oct 2010
    Melbourne, VIC
    The vibration damaged these parts. There's loads of room between his carby inlets and firewall.
  5. #905
    Boronia VIC
    Sorry I haven't gotten around to the videos yet. I'm on a very steep learning curve with the logger analysis software.
    Should be able to overlay some pretty clever stuff on the next videos.
    Just about got it figured out now.
    Here's an example of one of the easier to understand screens!
    7? MK1 Caddy
    12 Amarok
  6. #906
    Boronia VIC
    Pretty cool the number of options you've got for looking at data.
    Here's Gear by position through Honda
    7? MK1 Caddy
    12 Amarok
  7. #907
    Jun 2007
    Eastern Suburbs Melbourne
    wow, that is super trick!!
    i like volkswagens
  8. #908
    Boronia VIC
    Here's round 2 with some new overlays. Number between the clocks is which gear I'm in. Bar graph is wired to the brake light.
    7? MK1 Caddy
    12 Amarok
  9. #909
    vic
    Nice work Peter!
  10. #910
    Boronia VIC
    I just noticed something, in the video above the speedo is reading in miles. I'm still learning how to drive the software.
    7? MK1 Caddy
    12 Amarok
