Had to re-wire a chunk of the engine bay loom today. Didn't want to hit the track again with who knows what going on in the loom.
Here's what I extracted the engine bay. The hot wire to the temp sender had melted everything together all the way through the loom.
A bit hard to see but the old loom is at the bottom and the new one just above it.
I removed the un needed glow plug wiring and added a tacho sense wire into the loom.
Still need to find another two pin temp sender or work out how to convert the dash to the more common single pin type. I've included new wires in the loom but can't connect 'em 'till I sort out the sender. Meanwhile the VDO temp gauge is working fine so I'll just keep using that.
