Page 65 of 100 FirstFirst ... 1555636465666775 ... LastLast
Results 641 to 650 of 997
Thread: Wreck to Race.
  1. #641
    Sep 2007
    looks the goods pete.
    did you source the scirocco calipers from the states?
    i'm curious as to how much the koni shocks costed to rebuild..? i'm thinking about a set myself.
    87' MK2 GTI
    13' MK7 TDI
  2. #642
    Oakleigh VIC
    Yep, the 'rocco brakes came from the states from my trip last year.
    The Konis are about $100 each to rebuild if there's not too much wrong with them. (No bent shafts etc.)
    That's about 1/2 the price of buying new ones.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  3. #643
    Sep 2006
    Australia?
    Pete were those Konis my old ones from the cabrio?
  4. #644
    Oakleigh VIC
    Maybe
    The rears definately, I only had the one set. I've got a total of three sets of fronts though and I don't remember which ones were out of your cabby.
    7? MK1 Caddy
    12 Amarok
  5. #645
    What? Leaky AC Delcos? They're great! Nice and soft for jumping off the ripple strips
    DOH!! I got a set sitting in here with some King Springs (small budget - got hit by the GFC) and was going to put them in my Cab soon - are they REALLY bad!???
    I don't want to wait to get coilovers to be honest and my current shocks are really bad
    Current ride - MKVI GTI, Candy White, 4 door, Detroits, DSG, BT
    Previous VW - MK 1 Golf Clipper Convertible - 1993 - gone and now called Linda
    Previous VW - MK 1 Golf GTI 1983, Lhasa Green, Perrielli P's, euro front look, gone but not forgotten
  6. #646
    Aug 2008
    SYDNEY
    Quote Originally Posted by geeza View Post
    I ran these on my mk1. cheap solution for a budget run around. they were a million times better then the oil filled shocks that they replaced. For everyday use they arent bad.
    2008 POLO GTI - SOLD
    2005 MkV Golf GTI - couldn't resist
  7. #647
    Cheers for the info - i just need them to not crash though every bump / hole / rizla paper on the road so this would be fine
    Much appreciated
  8. #648
    Oakleigh VIC
    They're fine! I ran them on the race track for the last two years.
    Much better than stock oil shocks, just don't expect them to last 30 years.
    Mine were a bit leaky when I pulled them out and one was definatley stuffed but I did give them a pretty hard life.
    I'd use them again. Check e-bay there's always sets going cheap.
    Good value for money but will have a fairly short lifespan.
    Pete
    7? MK1 Caddy
    12 Amarok
  9. #649
    Oakleigh VIC
    Bugger, bit of a setback today. The clutch was slipping a bit so I just pulled the box.
    The clutch rod shaft was leaking bearing and seal were loose.
    I put another bearing in and discovered that the input shaft is split.
    Box will now need a full teardown to repair.
    Hmmm. Think I'll pop the old box back in the meantime.
    Pete
    7? MK1 Caddy
    12 Amarok
  10. #650
    oh geeez Pete, shocking set back
