Results 1 to 10 of 997
Thread: Wreck to Race.
    Jun 2006
    Orange NSW
    By the way, Pete, did you Mic that tunnel on the cap you replaced to check for ovality? I would assume that it should be pretty close, within a couple of tenths, but i'd be wary of that...
    Oakleigh VIC
    Did the best I could with the tools on hand
    I ran the cam in the tunnel with no lifters to check for binding and checked depth of cap from face to internal crown and across the diameter with a set of dial verniers.
    Reminds me, I must go and get some plastigauge.
    As I said, it's not ideal, should see me through the next season or until I get the other car on the track.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Oakleigh VIC
    Motor went in today. Here's some pictures.
    7? MK1 Caddy
    12 Amarok
    Oakleigh VIC
    While I was under the car I replaced the front exhaust hanger, I tend to go through a lot of them.
    This time I'm trying the updated VW Hangers from the cars with catalytic convertors, these should handle the heat a bit better. They seem a bit tougher all round reallt.
    Washed my socks today!
    7? MK1 Caddy
    12 Amarok
    Feb 2008
    Melbourne.
    thought I noticed them out the corner of my eye yesterday at your place, drying in the sun !
    Children(VW) who have left home, among others:1966 VW 1300 Deluxe Bug(Harbour Blue)1966 VW 1300 Steel Sunroof Bug(Ruby Red), 1971 VW 1600 S Bug(White) 1972 VW 25th Ann. Bug(Avocado) 2000 VW Golf Mk IV GTI 3 door(Metallic Black Magic), 1985 VW Golf Mk 1 GLS Cabriolet (Metallic Gun Metal) Current: 1985 Mercedes Benz 280CE Coupe(Midnight Blue)
    Sep 2008
    Bentleigh East Victoria
    Lathe plus smaller chokes = bigger chokes... Pete ... Wheel align, well that's another story all together ........ I run a small amount of toe-in say 1 mm or a little less. I've tried the VW setting which I think is a bit of toe-out but I find that it understeers a bit more which is note what you want on the gravel.
    Geoff
    Jun 2006
    Orange NSW
    Quote Originally Posted by Geoffrey Hale View Post
    Geoff
    Not much good if you want to keep the smaller chokes.. You can't machine it back on! haha.
    I've sent you a PM (questions) about front end alignment, Geoff..
    Jan 2006
    Looks good! Did you pick up any more top-end with the larger chokes?
    Oakleigh VIC
    Quote Originally Posted by Grunmk1 View Post
    HEAPS! ( I was just eating dinner before posting up the test drive results )
    So how does it go?
    Pulls all the way to 7000 rpm and there's still a little more to be had. Previously power died off by 5500.
    Acceleration has improved thanks to the slightly shorter diff and the wavetrac letting me put the power down faster and of course gob loads of extra power.
    The Wavetrac works well and will take some getting used to.
    Off at the lights I could just give it the lot and it just launched and around corners I couldn't get the inside wheel to spin no matter how hard I tried.
    There's something funky about the feedback through the steering wheel which I can't quite describe yet. It's not fighting you but it feels different when you load up the diff.
    It's running a couple of degrees hotter than before, but that might just be that I advanced it up a bit to start it.
    I'll see if I can get it on the Dyno and retuned.
    All I need now is a race track.
    Pete
    7? MK1 Caddy
    12 Amarok
    Aug 2006
    Melbourne VIC
    I notice a difference through the steering wheel comparing my car (Open diff) and Dad's Mk1 with the Quaife
