Page 51 of 100 FirstFirst ... 41495051525361 ... LastLast
Results 501 to 510 of 997
Thread: Wreck to Race.
  1. #501
    Sep 2009
    Chillaxing in Tas
    Cheers for that pete.
    Might go hunting for a Mk3 at a wreckers and grab some bits
    <space for rent>
  2. #502
    Boronia VIC
    Pulled the head apart today to clean out the galleries and de-coke the valves and chambers.
    This head was rebuilt, ported and installed on a 2.0 that only ran for 60km before spinning a main bearing.
    There's some scoring of the cam bearing journals . I polished them up and I think they'll be OK. I'll keep an eye on the oil pressure.
    Springs seem heavier than stock and there's titanium retainers in there. 8mm stems too.
    Inlet porting is pretty extensive, guide bosses have been completely removed in both inlets and exhausts.
    One bearing cap had a hairline crack and snapped completely when I test fitted the cam. I've put another in there from a 2.0 head. (Not really ideal, I don't recommend it for you kiddies at home.)
    Next time the head comes off I'll get the cam tunnel bored.
    Gasket is a Group A motor sport gasket 1.4mm uncompressed compared to 1.6mm of the metal gasket I pulled out.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  3. #503
    Boronia VIC
    I replaced the outer CV boot and repacked the CVs today.
    There was some other engine stuff to sort out as well.
    When starting the car it will sometimes backfire which is not a problem in itself but the cabin fill with the uncombusted petrol. So I went looking for firewall holes.
    There's gaps around the clutch cable dodgy repair, seam sealer fixed that.
    There was also a gaping hole in the steering boot.
    I replaced it and fabricated a new stainless steel heat shied.
    7? MK1 Caddy
    12 Amarok
  4. #504
    Boronia VIC
    I had to do some work on the carbs too.
    The ram tubes were painted black when I got them and I never gave it a second thought. Turns out that the paint isn't petrol proof and has been coming off. I guess the motor's just ingested it.
    I've cleaned the paint of a couple of them and they polish up OK so I'll leave them polished.
    I've also increased the chokes from 32mm to 34mm to aid with the airflow. Torque was never an issue and I'd prefer a few more revs over low down torque I can't use.
    Motor goes back in tomorrow.
    7? MK1 Caddy
    12 Amarok
  5. #505
    Jun 2007
    Eastern Suburbs Melbourne
    You've been a very busy boy havn't you Pete!
    hope it goes like stink when it's back together!
    i like volkswagens
  6. #506
    Jun 2006
    Orange NSW
    Looks good Pete. BIG valves! Haha. Nice!
  7. #507
    Boronia VIC
    It lives, and it's louder and faster than ever before!
    More to come.........
    Pete
    7? MK1 Caddy
    12 Amarok
  8. #508
    Jun 2006
    Orange NSW
    By the way, Pete, did you Mic that tunnel on the cap you replaced to check for ovality? I would assume that it should be pretty close, within a couple of tenths, but i'd be wary of that...
  9. #509
    Boronia VIC
    Did the best I could with the tools on hand
    I ran the cam in the tunnel with no lifters to check for binding and checked depth of cap from face to internal crown and across the diameter with a set of dial verniers.
    Reminds me, I must go and get some plastigauge.
    As I said, it's not ideal, should see me through the next season or until I get the other car on the track.
    Pete
    7? MK1 Caddy
    12 Amarok
  10. #510
    Boronia VIC
    Motor went in today. Here's some pictures.
    7? MK1 Caddy
    12 Amarok
