Page 50 of 100 FirstFirst ... 40484950515260 ... LastLast
Results 491 to 500 of 997
Thread: Wreck to Race.
  1. #491
    Boronia VIC
    It's out now!
    I'll work on swapping the head tomorrow. I need to pull it apart first and just give it a clean, and check the lifter clearances. (It's a mech cam).
    Decided to hang it on the stand off the back of the block. Just means I don't have to pull the clutch off.
    That casting on top of a 5 speed is conveniently right at the centre of gravity which lets you pick the box off the end of the motor without any back strain.
    The serpentine belt setup has held up to a year of racing no worries.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #492
    Nice work Pete, that was a quick engine pull out!
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
  3. #493
    Boronia VIC
    Quote Originally Posted by 16v_kid View Post
    Not so quick, I've been timed at 12 minutes to remove the engine from my old splitty Kombi.
    I did go to the movies for 4 hours yesterday too.
    This motor's a bit fiddly to take out though as there's lots of non standard stuff on it that has to be disconnected or that fouls when you're trying to remove it.
    Practice helps too.
    Pete
    7? MK1 Caddy
    12 Amarok
  4. #494
    Pete
    Like the twins huh?
    Golf GTI 1980
    Golf GLS 1979
  5. #495
    Jan 2008
    Surrey Hills, Melbourne
    Ah yes, the old air-cooled motor removal!
    Can you remind us again why you're removing the motor? New box and head, but I take it that's easier to do with the engine out? Or are there other fiendish plans in store?
    '76 Mk1 Golf - Gone!
    '05 Mk5 2.0 FSI Sportline
  6. #496
    Sep 2009
    Chillaxing in Tas
    looking good
    Where does one get a serpentine belt setup? i like the look of it
    And i take it the Alternator is a higher amp then stock Mk1?
    <space for rent>
  7. #497
    Boronia VIC
    Quote Originally Posted by greasykitchen View Post
    Just easier to remove as an assembly. I also wanted to go over everything before it goes out on the track again. Found a few loose nuts and clamps and stuff that I wouldn't have spotted otherwise.
    All I'm up to this time 'round is head, box and bigger chokes in the carbs, but it's never that simple of course. I spent a couple of hours today match porting the inlet manifold to the new head.
    Pete
    7? MK1 Caddy
    12 Amarok
  8. #498
    Boronia VIC
    Quote Originally Posted by GRN_VAGN View Post
    looking good
    You make one out of MK3 stuff. Here's how
    http://www.vwwatercooled.org.au/newf...ght=serpentine
    Alternator is a MK3 90 Amp unit, about double the output of a MK1.
    MK1 race cars tend to snap the standard alternator mounting brackets.
    Pete
    7? MK1 Caddy
    12 Amarok
  9. #499
    I'm going to need a new outer CV boot, hopefully I can can find one locally tomorrow so I can change it while the motor's out.
    Pete
    I might have a new one here in a box.
    I don't need it.
    You can have it mate.
    Not sure if it is inner or an outer though. Will check.
    cheers,
    Morgs
    76 Mk1 Golf 2dr 20VT BERG (project..)
    01 WRX
    89 SIR CRX
  10. #500
    Boronia VIC
    Like the twins huh?
    Carbs aren't so much of an issue. The extractors are one piece right back to the gearshift and they're clamped, not flanged so they're impossible to remove.
    Of course the extractors foul the inlet manifold too and it takes an hour to unbolt all of that.
    The alternator setup overhanges the the front chassis rail which stops me removing the motor downwards.
    The lower stress bar has to come out, and there's a remote oil cooler to contend with.
    There's just a lot of stuff to contend with.
    Pete
    7? MK1 Caddy
    12 Amarok
