Got it all together today and took it out for a run about.
Bucket loads of torque, really repsonsive throttle. It will break traction mid corner if you're carrying enough revs. Quite amusing really to steer it with the throttle mid corner, it's been a while since I could do that.
The light flywheel means you need a few extra revs on board to get it moving without stalling.
It's still untuned, I'm going to balance the carbs tomorrow and see how much static advance I can dial in, no sign of any pinging today.
Being the longer stroke, it's not as willing to rev as the 1800s but I don't think it needs to. The power is all there to be had below 6000rpm.
I might do a bit of experimentation tommorrow with cam timing and shift points.
It does run hotter than the GX, the only thing I can put it down to is the higher compression. The cooling system seems to handle it though.
I'm not thrilled about the oil pressure, seems to be lower than I'd expect. The oil I put in is a synthetic Fuchs 10w-40, I think I'll go for something heavier. Might have to investigate a new oil pump too.
At this stage I'm going to give it the green light to hit the track on Cup Day for the Group 5 sprints. Any volunteers for pit crew?
And yes - it's loud. Nothing stopping me from picking a bigger cam nowalthough this setup seems pretty tractable as it is, a bigger cam might push the power too far up the rpm range for the 2.0
Pete
