Page 29 of 100 FirstFirst ... 1927282930313979 ... LastLast
Results 281 to 290 of 997
Thread: Wreck to Race.
  1. #281
    Oakleigh VIC
    Oh, and the teks-nical term for "step drilling" is "Counter Boring".
    Counter boring it is!
    Here's the other end of that bolt, I used a counter sinking bit to chamfer the cable exit point to reduce wear.
    I didn't want to modify the pedal too much so I clamped m8 mudguard washers either side of the circular part of the top of the pedal. This should keep the cable bearing on a smooth radius.
    Tha cable's clamped against the shaft of the pedal with a thick m6 washer, bolt and nylock .
    Pretty happy with the way it turned out, I might make up a spare to keep handy trackside but I think this will last for quite a while.
    Pete
  2. #282
    Camden, Sydney
    You could use a dissy from a carby Mk2 or Cabriolet or Scirocco for one with hall effect sensor and mechanical advance
    Have missed this thread for a while, just re-read it all. Nice work. Carbys will probably go better than the kjet, but use more juice.
    I didn`t have to modify the rail on the Mk1 Caddy or the Rocco for the bigger belt setup, maybe its a year model thing.
    Have fun on the track
  3. #283
    Oakleigh VIC
    Got any to spare?
  4. #284
    Oakleigh VIC
    Here's what they sound like.
    There's no video , just some fuzzy pics to keep the bandwidth down and because it was too dark.
    (Hope this works)
    The clip is 2 minutes form cold start. Didn't fire first go because I didn't pump the throttle at all. Second time it fires there's a delay as I move from reaching through the window to turn the key to getting to the throttle linkage in the engine bay all while juggling the camera in one hand.
    Didn't give it much of a rev for this either, the engine's cold remember.
    Pete
  5. #285
    Eastern suburbs of Melb
    very nice pete! very impressed!
  6. #286
    that sounds....... EROTIC !
  7. #287
    Jun 2006
    Orange NSW
    Sounds almost as good as a 16v....
    Very nice. Gotta love the gasping induction note when the engine is cold and you rap the throttle.. It sounds like the engine is gasping for air. (When in reality, it's the opposite, haha).
  8. #288
    Jun 2007
    Eastern Suburbs Melbourne
    Oh that sound!!
    hopefully I can make it to your next track meet, even if only to hear that sound!!
    i like volkswagens
  9. #289
    Oakleigh VIC
    Got it all together today and took it out for a run about.
    Bucket loads of torque, really repsonsive throttle. It will break traction mid corner if you're carrying enough revs. Quite amusing really to steer it with the throttle mid corner, it's been a while since I could do that.
    The light flywheel means you need a few extra revs on board to get it moving without stalling.
    It's still untuned, I'm going to balance the carbs tomorrow and see how much static advance I can dial in, no sign of any pinging today.
    Being the longer stroke, it's not as willing to rev as the 1800s but I don't think it needs to. The power is all there to be had below 6000rpm.
    I might do a bit of experimentation tommorrow with cam timing and shift points.
    It does run hotter than the GX, the only thing I can put it down to is the higher compression. The cooling system seems to handle it though.
    I'm not thrilled about the oil pressure, seems to be lower than I'd expect. The oil I put in is a synthetic Fuchs 10w-40, I think I'll go for something heavier. Might have to investigate a new oil pump too.
    At this stage I'm going to give it the green light to hit the track on Cup Day for the Group 5 sprints. Any volunteers for pit crew?
    And yes - it's loud. Nothing stopping me from picking a bigger cam now although this setup seems pretty tractable as it is, a bigger cam might push the power too far up the rpm range for the 2.0
    Pete
  10. #290
    Jun 2007
    Good to hear it's all running well.
    Is Cup Day this tuesday? and is it at sandown?
    i like volkswagens
