Page 28 of 100 FirstFirst ... 1826272829303878 ... LastLast
Results 271 to 280 of 997
Thread: Wreck to Race.
  1. #271
    I'm surprised that you're running out of fuel with one of these pumps, they'll usually flow litres per minute. I used one on my 1835 beetle feeding twin 40 DCNs and it had no problems, even with some pretty massive fual comsumption under race conditions. (About 5 + litres / lap of the old Morwell Hillcimb track)
    Pete
    nah i havent quite fitted my one yet mate, it was running out of juice with the mechanical fuel pump
  2. #272
    It's a modified 1600 one. Basically you pull the vacuum advance plate and can out and have the dizzy recurved. From memory I think it's 30° all in by about 3500rpm similar to the aircooled 009s. I'll have to check those figures.
    Pete
    yeh thanks!
    Atm i've just plugged the vacuum advance holes, but i'd rather do it right
  3. #273
    Oakleigh VIC
    Fired it up!
    Props to the Carby shop, pretty well balanced and idling at 1000rpm with no adjustments from me.(Yet)
    I kept thinking to myself while fitting and refitting the manifold for 6 hours yesterday "Is this worth the effort?"
    All doubts gone as soon as I heard the induction noise, I'll be grinning for a while now.
    It's still to be driven, there's a throttle cable to finish off and the dizzy to swap out yet.
    Pete
  4. #274
    Eastern suburbs of Melb
    Fired it up!
    Pete
    Good work pete!
    thats what i like to hear!
  5. #275
    Jun 2006
    Orange NSW
    Congrats, pete. Glad to hear she fired up with no issues!
  6. #276
    Oakleigh VIC
    Throttle cable's done now, very pretty, it almost deserves a thread of it's own. Tomorrow night I'll swap the dizzy and coil out ready for tuning on the weekend.
    Pete
  7. #277
    Jun 2006
    Orange NSW
    Well where's the pics of the throttle cable then??
  8. #278
    Jun 2007
    Eastern Suburbs Melbourne
    Good to hear Pete.
    best get a video for all to see
    i like volkswagens
  9. #279
    Oakleigh VIC
    $2.99 Huffy universal brake cable from K-Mart Cheapest part of the exercise.
    Starting from the Carby end.
    I turned down a section of bolt, cross drilled it and sweated the cut end of the cable into it using silver soldering flux and convential electronic 60/40 solder.
    To retain the sheath of the cable I centre and step drilled through a M8 bolt this will provide fine adjustment of the cable length if required. The bracket the bolt is screwed into was tapped and a nut is used to lock the adjustment.
    At the firewall the hole into the cabin is quite large so I used a 12mm flanged bolt again step and centre drilled. By step drilling I mean that I drilled a 2mm hole right through the bolt and opened it up at one end to 5mm to a depth of about 7mm in order to retain the cable sheath. Neat , huh?
    Time to eat dinner now I'll show you the pedal end when I've eaten!
    Pete
  10. #280
    Jun 2006
    Orange NSW
    The way you've done the cable is the way i've been pondering doing mine. Bike brake cable and all! haha.
    I like how you've attached it through the firewall. That's very trick. Nice and simple too. I wouldn't have thought of that.
    Oh, and the teks-nical term for "step drilling" is "Counter Boring".
