Page 23 of 100 FirstFirst ... 1321222324253373 ... LastLast
Results 221 to 230 of 997
Thread: Wreck to Race.
  1. #221
    Boronia VIC
    Quote Originally Posted by AUC-05L View Post
    excelent thread mate, will be doing the same conversion when the 1.6 ****s itself so a tech article would be awsome.....
    keep up the good work!
    cheers
    john
    I've got plenty of pictures. I'll write up something for the conversions thread when I get the time.
    Meanwhile feel free to ask me anything specific.
    If you're going to use the 2.0 head there's other issues I haven't had to address because I'm using the 1800 k-jet head.
    Pete
  2. #222
    Boronia VIC
    Had to make a spacer for the Engine mount bracket. Normally the Alternator mount tucks under here.
    Bolted up all the pullys and belts after torquing the head. Those stretch bolts take an effort!
    Pete
  3. #223
    Boronia VIC
    Assorted Clutch assembly shots.
    Pressure plate is a new Sachs 210mm 16v unit.
    Driven Plate is 210mm Heavy duty sachs.
    Flywheel is MK2 210mm and is much lighter than the 190mm MK1 unit.
  4. #224
    Boronia VIC
    Close ratio box mated up to motor, ready to put into car first thing tomorrow.
    Pete
  5. #225
    Jun 2007
    Eastern Suburbs Melbourne
    Looking good Pete
    i like volkswagens
  6. #226
    Boronia VIC
    Today's adventures. Off to an early start. Up, up and away!
  7. #227
    Boronia VIC
    First issue of the day. The alternator tensioner fouls the body work. I was sort of expecting this, it's been mentioned around here before.
    Some minor adjustments were required.
    That cost me a couple of hours to sort out. Hopefully you can all see what needs to be done if you're going to try the serpentine belt setup yourself.
  8. #228
    Jun 2006
    Orange NSW
    Hmmm... Looks like i'll be needing to do some "Minor adjustments" too when i go that way.
    I take it everything went well?
    By the way.. Sprung clutch?? Soooooft.
  9. #229
    Boronia VIC
    Another little clearance issue caused by the addition height of the 2.0 block. Easily fixed by bending the raintray.
    It's in! Now just to do the plumbing and wiring.
    Before the dizzy went back in I primed the oil system by using this to drive the oil pump directly throught he distributor hole.
  10. #230
    Boronia VIC
    With urethane mounts all round I though A solid 3 puck disc might be a little too exciting.
    Pete
