Page 19 of 100 FirstFirst ... 917181920212969 ... LastLast
Results 181 to 190 of 997
Thread: Wreck to Race.
  1. #181
    Boronia VIC
    Thats a serious oil light, pete! good stuff.
    Hehehe. It's a busted Mk1 clock and a LED downlight globe
    I could have put a red 50w incandecent in there but I figured I might not be able to see the track past it.
    Those globes come in other colours too. I could make me a disco dash.
    Pete
  2. #182
    Jun 2006
    Orange NSW
    Pete
    Hahaha, quality. You certainly come up with some good ideas. I like your enginuity (pretty sure that's spelled incorrectly..).
    You know what they say.. Necessity is the mother of invention.
  3. #183
    Boronia VIC
    Today's race prep photos.
    Here's a few shots from prepping the car today.
    Interior before
    After
    Finally got hold of a driver's side belt buckle to keep the lap sash belt functional (and therefore legal) for road use.
    Belts all tucked away for the drive to Sandown tomorrow.
    Going to try some new oil. I had just done a change but there was still a lot of water in there from the head episode.
    So much for VHT heat proof paint.
    I found an eye bolt that conveniently winds into the tow bar instead of the tongue. The factory tow point needs welding to be usable.
    This is a bugger, I overtightened the adjustable cam pulley and stuffed it up. I'm pretty careful with these things, no torque was specified. I was using a short allen key with no additional leverage. doh!
    I'll order in a stock pulley and get it machined to replace the bit I broke - perhaps with a little more material left around the bolt holes.
    I was intending to run it at 0 degrees anyway. I've put a stock pulley or there ftm.
    Pete
  4. #184
    Jun 2006
    Orange NSW
    Pete
    That's a bugger
    Send it up and i'll do it for you if you don't know any good people.
    You mounted your seatbelt buckle on the side the same way i did with my custom seats... Great minds think alike huh?
  5. #185
    Boronia VIC
    That's a bugger
    Cheers, I might just do that once I've got a new stock pulley in.
    I had to have the seatbelt buckle in their as well as the harness because of the way the laws down here work.
    Basically if the car came factory with retracting seatbelts then non-retracting seatbelts (ie Harnesses) are not legal for that car when it's used on the road.
    So its fine to put harnesses into a 1965 Beetle just not a '79 Golf !
    I've got wave washers on the buckle so I can fold it backwards when the harness is in use.
    You can see where it's attached in this shot. It's an early seatbase so it didn't have the factory bracket inside the runner.
  6. #186
    Jun 2006
    Orange NSW
    Wave washers.. Now there's something i didn't think of. Good idea. If only i was going to use those seats again...
  7. #187
    Perth. WA
    Pete
    VW engine sprockets are all sintered metal, basically crap material Pete, Prob better off long term using a HARD anodised Alloy one ( not colour anodised, hard anodised is a gunmetal grey colour ).
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  8. #188
    Jun 2006
    Orange NSW
    Quote Originally Posted by roccodingo View Post
    The quality of them isn't too bad in my opinion. They are soft, but not weak. Hard annodising is only case hardening process. Yes you can "harden" aluminium alloys, but in most cases companies use T5 or 6 anyway, so it won't make any difference and they won't be any stronger for this application in my opinion.
  9. #189
    Perth. WA
    Prob is the sintered ones have low ductility, fine if your leaving them in an original unmodified state, however the material doesnt take to kindly to the stresses of drilling and tapping once the sintering process is completed..
    Cheers,
    Grant...
  10. #190
    Jul 2005
    Newcastle, NSW
    Quote Originally Posted by Water Boy View Post
    Replace the fuel with a big orange light so if there is no oil presure it turns on and that means shut the baby down... Saves some money just incase things goes wrong...
    U can get the presure thingo in the head
    on this, my Imp has a static fuel pump that only pumps when there is oil pressure in the engine. Oil pressure switch down stream from the fuel pump electrics. If you have no oil, you won't go anywhere....
    Surely to save an early rebuild.
