A busy weekend, but not much to report on the car front.
I got the wheel bearing sorted out and back in. The Brake place (Better Brakes in Bayswater) were kind enough to not charge me for the fitting again.
I dropped the Alternator off, but I'm not going to get that back until tonight at the best.
I've also booked in for a Harness bar to be fabricated at Brown Davis http://www.browndavis.com.au/
Fire extinguisher is in now.
Rewired power feed from battery for the fuel pump circuit. When I fixed up the relay I wasn't happy with the way the power feeds for the K-Jet loom and pump were setup. They were both on a piece meal run from the battery and had a glass inline fuse in the run in a hard to get to spot in the engine bay. (Under the overflow tank!)
I've re-powered the Engine loom via a relay off the fuse box and re-run the pump wiring direct to the battery and installed a re-settable circuit breaker under the dash.
I've also put the factory breathers back in place to avoid having to run a catch can.
I fiddled about with the mounting of the fuel distributor to get it sitting better in the engine bay. While it was out I drilled and tapped it for the breather fitting and painted up the Bunnings CAI plumbing and cleaned the rice I mean air filter.
I've ordered a new fuel Filter and Radiator hoses just to be on the safe side. I currently have a Mitsubishi fuel filter fitted because it has the right fittings and was all I could get at the time. It's bigger than stock but never really fitted in the bracket properly.
Apart from all of that I also managed to catch Rosin Murphy at Billboard on Friday night, an awesome show, although the DJ beforehand sucked.
Saturday afternoon I had to play chainsaw Harry and cleaned up storm damage and on Sunday morning we headed out to Jeff's shed to check out the Toy Fair which is always a financially dangerous thing to do.
Next Saturday I'll see if I cant get a couple of the fuel hoses in the engine bay fixed up at a hose place. The high pressure lines between the body, filter and distributor have cracks in the outer sheaths, I'm sure that they're sound but a scrutineer might not feel the same way.
Pete
