Page 3 of 100 FirstFirst 123451353 ... LastLast
Results 21 to 30 of 997
Thread: Wreck to Race.
  1. #21
    Jun 2006
    Orange NSW
    Looking good pete! Good to see you're not taking short cuts.
  2. #22
    Oakleigh VIC
    The odd injector is from an early Mk1 GTI. All the others are from the later Mk2 kjet 1.8s. I`d use the later kind in that motor.
    You have had a busy weekend, good work.
    Thanks Matt, That's one day's work, I got a free seat at the GP yesterday
    Now I know What I'm looking for in injectors I might grab some off US ebay.
    I was surprised how easy they are to take in and out.
    Pete
  3. #23
    Jun 2007
    Eastern Suburbs Melbourne
    yea good work pete.
    have you even gotten around to changing the brake pads yet?
    i like volkswagens
  4. #24
    Oakleigh VIC
    I've been tempted! It was close there for a while with that crank pulley.
    I had to use the sort of torque usually reserved for beetle axle nuts.
    I'm going to re-visit that water pump one day when I've collected enough bits to run a serpentine belt. I already have a new Mk 3 pump, tensioner and alternator, all I need is the pulleys and the time to hunt down what the right sized belt is going to be. I think Valver has done something similar.
    There's been a bearing noise, I thought it might have been the pump but it checked out OK so I' re-used the original pump after cleaning out the housing and replacing the gasket.
    The noise turned out to be the alternator bearings so I'll have to drop that off at the auto sparky for some TLC.
    Pete
  5. #25
    Jun 2006
    Orange NSW
    So you're saying you got the longest bit of pipe you had on the breaker bar and jumped on the end of it?
    Know the feeling, it took both my old man and me to get one off an early combi at the workshop once..
  6. #26
    Jun 2006
    Orange NSW
    You'd be correct. I asked him about it in his project thread and he put all the details on there. I'm going to be doing the same thing.
  7. #27
    Oakleigh VIC
    yea good work pete.
    See page 1 of this thread.
    New TRW pads all round.
    I haven't fitted the rear discs yet 'cos I backed the car into the garage and I can't get it out till I've got the front back together. I'm also waiting on rear suspension bushes so I can drop the beam right out while all the brake lines and cables are disconnected. Might just have to paint it red!
    The TRW pads were recommended to me by my brake shop as being comparable to the EBC Greenstuff pads which are not available for my front callipers. They're soft which means they should bite well but can be dusty, which doesn't bother me. They're also good for 650 degrees and a good compromise for road and track I was told.
    I'm with holding judgement 'till I've driven on them.
    The pads I was using were new ols stock when I got them and contained ASBESTOS. Great!
    Pete
  8. #28
    Jun 2006
    Orange NSW
    Pete
    I know a guy that sells EBC greenstuff pads, and he can get the 239mm GTI pads... Well atleast last time i spoke to him.. How come you say they are not available?
  9. #29
    Oakleigh VIC
    Almost.
    We once "borrowed" the stop sign from the end of the street to use on a 3/4 breaker bar to get a beetle axle nut off. The brakes wouldn't hold that Kind of leverage of course, we had another bar bolted up with the wheel bolts.
    Was sort of fun, you could pick the car right off the ground and the nut still wouldn't let go. We ended up drilling and splitting the nut.
    (We put the stop sign back when we were done)
    Pete
  10. #30
    Jun 2006
    Orange NSW
    Almost.
    Pete
    Haha! Yeah, it's amazing how tight some things can get. The old man has taken a cold chisel to them before and split them off..
