Great looking car Pete!
Where do you find the time to prepare one and race another???
Printable View
By not watching TV. :rolleyes:
I've been trying to track down my power loss issue.
I haven't been able to find an obvious cause yet.
I pulled the carbs apart, the float levels were only off by a couple of mm.
As a precaution I've changed the fuel filter and pump as well.
The ignition leads check out. I might replace the coil just in case.
I was struck by the thought that it might have been a tappet closing up so I checked all the valve adjustments today.
There were only 2 that were marginal and they were only 0.02 under minimum. I managed to find fractional shims to bring them back in line. I doubt they were the cause.
Amazing how clean a race motor stays inside.
http://www.vwwatercooled.com.au/foru...P1350670-1.jpg
:( :confused: Well that's everything I could think of at Sandown that day plus the tappets :confused: :(
I hope it all comes good when we're back there in July.
Did you see the extra pics of White and the Pod by the HSV Owners' Club photographer?
What a bugger..maybe its time to drill out some injector ports and run electronic fuel management Pete?
I've got a whole other car for that!:)
OK, I don't think there's anything else to fix now.
I replaced the hall sensor in the dizzy which I think was the culprit of my recent racing woes.
Upon trying to restart and tune the car afterwards I discovered the the filter just prior to the carbs was blocked.
It's a glass unit and didn't look blocked at all, but blowing though it proved it was almost completely blocked.
With the filter in place a 10 second bust on the fuel pump only put a couple of teaspoons of fuel into a handy coffee cup.
Without the filter 10 seconds had the cup full to the brim.
I've got a new tank filter on the way I'll replace that, the one prior to the pump and the one in the engine bay next weekend.
Seeing as I had all the bits to diagnose the ignition, I also replaced the coil, cap, leads, rotor and ignition module.
Having your best parts in a box on the side of the track doesn't make you go faster.
It'll be a while before the next outing, I need the time and money to finish the other car.
I think White's getting jealous of all the attention that the Kamei is getting :facepalm:
not sure if you have seen this Pete, but mikes car got ALOT of attension over the weekend at the GTI International.
http://sphotos.xx.fbcdn.net/hphotos-...96680858_n.jpg
:banana:
Yeah Mike and I follow each others progress pretty closely and exchange emails regularly.
Makes me smile to think I supplied the indicators that are on Mike's car in that Photo.
Not sure what reaction my car will get here there's been nothing quite like it built here for a very long time.
Sent from my HTC Sensation Z710a using Tapatalk 2
