Had similar issues with replaced wheel bearings here Pete, unsure if it was from :-
1. weight of vehicle on bearing with nut not fully tensioned for a short period of time ( week or so )
2. Alignment not done before driving virtually any distance.
3. defective bearing or installation of bearing
Being a fitter/ machinist by trade basically discounts #3, my money is on # 2 as it has happened several times and even after having the front end aligned at a " tyre shop "
So now i tension the nut as soon as the wheel is on the ground, and align the wheels myself ( camber at the very least !!)
Have had instances where the front bearing has begun to fall apart when moving old cars about with loose axle nuts...
HTH. project is looking very good for limited time and budget mate, job well done
Lots of MK 1 Scirocco's...
Cheers,
Grant...
