Page 6 of 100 FirstFirst ... 456781656 ... LastLast
Results 51 to 60 of 997
Thread: Wreck to Race.
  1. #51
    Aug 2006
    Melbourne VIC
    Weight reduction - Tow bar
  2. #52
    Oakleigh VIC
    Quote Originally Posted by Water Boy View Post
    I need that there for the moment. But point taken.
    There's a quite a few things that could come out yet.
    Just got to strike a happy balance between track and street.
    Pete
  3. #53
    New Ball joints
    I managed to get the new tie rods in before dark today too. The inner ends on the old ones are pretty loose and had a small amount of play in them.
    Just out of interest Pete & if you don't mind me asking,
    How much were the Ball Joint's & Tie Rod assemblies & where did you get them from?
  4. #54
    Oakleigh VIC
    Quote Originally Posted by golfworx View Post
    Right here actually!
    Matt (Golf Loon) sourced two sets of balljoints and tie rod ends for me and sent them down. Not sure what the individual prices were on the bits, ask Matt for a quote.
    When I went to fit the tie rod ends I discovered that one side is a fixed length and has a tie rod end crimped on so i couldn't actually change the tie rod end on that side.
    By coincidence Andrew (gtimk5) had listed some brand new assemblies for sale in this post for $75 ea. http://www.vwwatercooled.org.au/newf...ad.php?t=13209
    It turns out that you can fit the adjustable rods to both sides, they're the same.
    The assemblies I got from Andrew came as pictured, he was kind enough to include the new rack boots too.
    I'm going to use the old adjustable rod to go into my other golf and just change the rod ends on that car.
    Pete
  5. #55
    Jun 2007
    Eastern Suburbs Melbourne
    Your engine is truely a mistery Pete!
    Nice progress, you've got a fair bit dont recently as it turns out! Don't forget to enjoy easter!
    i like volkswagens
  6. #56
    Jun 2006
    Orange NSW
    Funnily enough when i put a tow bar on my car it made it handle better. It stiffened up the back and relieved the slight mid-corner understeer it had, making it very neutral. I could chuck it into a corner and make it do whatever i wanted instead of getting that bit of push that tended to make you stay off the throttle for longer than i'd like.
    Could almost be an advantage for a track car.
    I'm going to make brace and put it in the boot between the bumper mounts and utilise the bumper screws to help stiffen the back up in my car.
  7. #57
    Aug 2006
    Melbourne VIC
    Why not just run a rear stabilizer bar
  8. #58
    Jun 2006
    Orange NSW
    Yeah but i'm talking stiffened the chassis up, it wasn't a weight transfer issue.
    I'll be running front and rear stablizers too,
  9. #59
    Oakleigh VIC
    Today's work.
    Out of the garage and up on the stands.
    Off with the brakes!
    The parts are piling up.
    It's out!
    Now there's some weight reduction!
    These things are a PITA to get out but an even bigger PITA to get back in!
    Re-assembly.
    I was going to paint this black but I was told in no uncertain terms not to deviate from the red paint scheme. At least the track marshalls will know which way up my car is!
  10. #60
    Jun 2007
    Good work pete. I've always wanted to paint a rear bar red for some reason. I don't know why?!
    So what's the red spray can count up to now? that's alot of painting you've been doing!
    How difficult is it to get the rear bar off? 4 bolts and she's done is it?
    i like volkswagens
