This sump hasn't seen the track yet. I paint them red so that the marshals know which way up to put the car. :nana:
Pete
Printable View
Motor's coming out tomorrow. I'm taking a day off to catch up on the car work :). Plenty of pics to follow.
Probably won't get the new one entirely back in tomorrrow there's a few things need doing while the engine bay is clear.
Saturday I'll be loading the trailer up for the swap meet.
Pete
Awesome Pete can't wait to see what you get done! :)
good luck
so you'll be home all friday then?
Got the motor out by 12:00. Finally figured out the timing issue, some moron had bolted the flywheel to the pressure plate the wrong way! Even clamped it down on one of the dowels so it's actually buckled the pressure plate.
Anyone want a GX Block?:)
Pics later.
Pete
Here's a few pics of the close ratio box getting ready for a new clutch.
Here I've replaced the throwout bearing, shaft bearing and oil seal.
http://www.vwwatercooled.com.au/foru...P1310833-1.jpg
http://www.vwwatercooled.com.au/foru...P1310835-1.jpg
http://www.vwwatercooled.com.au/foru...P1310836-1.jpg
http://www.vwwatercooled.com.au/foru...P1310837-1.jpg
http://www.vwwatercooled.com.au/foru...P1310838-1.jpg
Today's motor removal.
http://www.vwwatercooled.com.au/foru...P1310839-1.jpg
http://www.vwwatercooled.com.au/foru...P1310840-1.jpg
http://www.vwwatercooled.com.au/foru...P1310841-1.jpg
http://www.vwwatercooled.com.au/foru...P1310842-1.jpg
http://www.vwwatercooled.com.au/foru...P1310843-1.jpg
http://www.vwwatercooled.com.au/foru...P1310844-1.jpg
http://www.vwwatercooled.com.au/foru...P1310845-1.jpg
http://www.vwwatercooled.com.au/foru...P1310846-1.jpg
http://www.vwwatercooled.com.au/foru...P1310847-1.jpg
http://www.vwwatercooled.com.au/foru...P1310848-1.jpg
Leaky rear main seal.
http://www.vwwatercooled.com.au/foru...P1310849-1.jpg
1800 k-jet head sitting on the 2.0 block.
http://www.vwwatercooled.com.au/foru...P1310850-1.jpg
Here's the block off plate I made up to seal odff the 2.0 Breather box.
The mounting plate for the warm up reg will bolt right on top.
http://www.vwwatercooled.com.au/foru...P1310851-1.jpg
http://www.vwwatercooled.com.au/foru...P1310852-1.jpg
There's a few more fiddly bits to sort out yet, but with luck I'll pop the new motor in next weekend.
Pete
