Looks the biz Pete. Can't wait too see how this combo performs!
Printable View
We've been a bit busy the last few weeks looking after a friend whos going through a seperation so I haven't had much time to play with the Mk1.
Here's where it's up to at the moment.
Made up a new vacuum connection for the airshrouds on the injectors. I'm waiting on a delivery with the new insulators, should be here next week.
http://www.vwwatercooled.com.au/foru...P1300333-1.jpg
Here's why I never could figure out the timing, see I'm not going crazy!
When the mark is here,
http://www.vwwatercooled.com.au/foru...P1300334-1.jpg
The pistons are here !! :?
http://www.vwwatercooled.com.au/foru...P1300335-1.jpg
I guess whoever bolted up the clutch / flywheel didn't know what they were doing!
As it sits now,
Head back on, exhaust bolted up hoses re-attached. Still need to pop some assembly lube on the new cam and lifters before firing it up, its drenched in light machine oil at the moment.
http://www.vwwatercooled.com.au/foru...P1300336-2.jpg
Hopefully I'll get some work done this week and be ready for when my parcel arrives.
Pete
can't wait. when's the next track event?
Looking good Pete, keep up the no BS approach. I'm lovin it.
PS, just set the ignition by feel.. If it rattles, back it off a smidge.. :D
That's exactly how I do it! I've never owned a timing light! Never could see the point!
I normally set the timing statically and then advance it 'till it pings and back it off a bit!
It was more the cam timing that was confusing me with the markers all out of whack. When I got it the intrmediate shaft was out of phase too which wasn't making things any clearer.
It's all good now though. :)
Pete
I might be able to do something in July. Have a month and a bit off with uni, so if you do do anything, be sure to let me know!
Another parcel from GermanAutoParts!
http://www.vwwatercooled.com.au/foru...P1300344-2.jpg
I should have enough bits now to get it running again over the long weekend.
Pete
