This. Is. Awesome!!!!
Love it man, I bet it was super fun before, imagine when you're done!?!
My all time favourite type of MK2 - a 2 door running a real turbo diesel motor. 300hp with 60 mpg, doesn't get much better than that.
Love your work.
Have you allowed enough flex in your pipes to allow for engine movement and vibration? From this picture it looks like you'll be wearing out something soon.
Paul
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
- Brown U.S import 81 cabby
- 88 Honda crx b18cr
Don't get any ideas George. MK1 GTI's don't run on diesel.
And double that will be "adequate".
What a cool project - keep it up. A modern diesel in a classic VW body!! You are certainly a handy chap on the tools and DIY too.
Also saw you have a Golf R. What plans have you got for that?
I made the Side exit exhaust which takes a few minutes to swap between one exhaust and the other. using a V band clamp.
also heat wrapped the lower section of the down pipe, to protect the CV Joint. and surrounding tunnel area.
Need to make some additional heat shielding to protect the Brake Hard lines from Turbo heat-soak.
Going to do some Data logging today... to get the tuning underway.
