Page 9 of 13 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 127
Thread: VW Mk2 Golf "Deep Blue" project
  1. #81
    Jun 2012
    Auckland, NZ
    After quite a lot of fiddling around for it on Friday and not being able to get it firing (which I realized just as we ended for the night that it was because my ignition leads were in a random order as i just placed them on and forgot to re-arrange them, guess how I feel!) we managed to get it firing yesterday.
    It started a couple of times but can't get it going again, the battery seems too weak as it struggles to turn the engine over. Will get a bigger battery and see if that helps. Was really happy though when it did fire because it just fired right up, no struggling or pumping the pedal for ages. Also still need to wire an oil pressure safety switch for the fuel pump as now it runs constantly on with the key on run even if the motor is off, and need to sort the small fuel leak coming from the FPR.
  2. #82
    Jun 2012
    Auckland, NZ
    The battery was the issue, just picked up a larger one and the car has started multiple times. Tuning time now, I need to fiddle with the idle mixture as it's idling at around 1500-2000 and I can't get it to go lower with the main idle screw plus revs are returning really slowly, all signs of a lean mixture (as far as I can find out) so will have a play with the the idle mixture screws a little later and see what I can do.
  3. #83
    Jun 2012
    Auckland, NZ
    Took the car out for the first drive yesterday just around the block, I'm very pleased with the results. It's by no means running right, currently it idles anywhere between 1200-2200 revs and I haven't even begun to tune it, so I can only imagine how well it will go when I sort it out. I still need to sort a few other issues such as a leak from the lower radiator hose that I improvised and I need to install an oil pressure safety switch for the fuel pump as well as a radiator fan sensor switch. My main fuel pump is not currently working so I have bypassed it and am just running the intake pump which seems to provide the needed 3psi. I will try and claim warranty on the other pump as I only started the car 3 times with it and now it only pumps drops of fuel, not sure what's going on there. Will try to get pictures and videos up soon.
  4. #84
    Jun 2012
    Auckland, NZ
    Right guys, time for photos:
    I have been playing around with the carbs and have got it to idle pretty smooth now at about 950 rpm so I'm guessing they are close to balanced. The revs also return nicely now and it goes as it should. Still need to do a bit more to get it perfect, I know a guy who has put these carbs on mk2 escorts so will go and see him to make sure everything is ok. Have taken it for a few drives around the block, I've very pleased with how it goes. Quite a bit of torque steer when flooring it in first, makes me smile every time.
  5. #85
    Jun 2007
    Eastern Suburbs Melbourne
    nice, looks and sounds good!
    i like volkswagens
  6. #86
    Jun 2012
    Auckland, NZ
    Thanks mate
  7. #87
    Jan 2014
    looks real nice man, just a quick question where did you get those wheels??
  8. #88
    Jun 2012
    Auckland, NZ
    Thanks man. The wheels are mk3 steel wheels which I had widened.
  9. #89
    Aug 2013
    London
    You have no idea how much I want your MK2! And those steels look great on it too
  10. #90
    Jun 2012
    Auckland, NZ
    Quote Originally Posted by mike1990 View Post
    Thanks man, appreciate the kind words
