To divert my attention for a while, i decided to sort the suspension.
Lowered pedders springs from a forum member, GTI shocks, and new springs in the rear.
New on the left, old on the right - no they are not going into the lawn mower...
Rear spring in the background.
Simple job to remove the bolts from the rear shock bases, drop the rear subframe (partially) and simply insert the rear springs. And they are red - it was meant to be. They still had a part number sticker on them, so I rang Pedders to confirm - VW Golf MK4 lowered, ok for GTI - cool, good to go in.
Is that a Whiteline rear anti sway bar in the background . ..adjustable, same source as my TT brakes, what a great forum
It so happens the the rear disk size is the same for the 1.6, GTI and Audi TT mk1, so these dont have to be changed.
However, the fronts do. I have a set from an Audi TT with 312mm disks - so big fronts going in. Initially I had all the bits except for the carriers, so I did the front shocks and springs and put the originals back on - they will still stop the car , but it will be under braked for spirited driving - oh, and it's not compliant without the upgrade either....
Seb and Courney (Bugracer and white vr6) are sorting the carriers, expecting them very soon...
Original brakes, new (well used A3 1.8T) shocks and (newish aftermarket) springs
Rear antisway bar goes on next:
U bolts go over the rear sub frame (instructions are on their site in PDF)
Droplinks mount to a spacer block at the base of the rear shocks
Select a hole for stiffness - towards the end has more flex, so second stiffest setting here:
