well yes the body is sitting on the ground![]()
Originally Posted by ausgolfer
pppffftttt to low as if. u cant go too low![]()
mk2 GTi 16v
Corrado G60
when do you get the engine?loving it!!!
Funny you should ask that Josh, the engine arrived this morning.
Now question time starts.
The oilfilter mount is cracked as you can see in this picture and not sure if this could be welded because of the thread.
mk2 GTi 16v
Corrado G60
Here are the clocks and ignition.
and the engine mount looks like it wouldn't be too bad to mount on a future chassis rail.
as will the tranny mount which will be a little lower.
mk2 GTi 16v
Corrado G60
Funny thing, I was looking for the engine number in the original mk1,2,3 positions and couldn't find any, but a sticker on top of the motor says AGU followed by 6 digits. So am assuming that is the engine number.
The Cut has come without an airflow meter and the top half of the air box.....if anyone knows where to get an airflow meter for this motor cheap please let me know. But I imagine it'll be a long while before it's up and running.
Some initial measurements have shown that the towers are in a fairly decent position for going under the back of the manx shell without too much fuss. I'll bring them forward a bit for a more upright position (they lean back a little in the original position) and probably inward a little.
mk2 GTi 16v
Corrado G60
A few things I'm keen to know is what I need to retain of the wiring to keep the ecu and motor going? for example if I remove the wiper motor will the ecu still work? Obviously I want to get rid of as much as possible.
Also there's lots of random bits to the fuel system which I'm unfamiliar with. and I'll need to know what I can turf.
The power steering pump and the a/c compressor are gone and there's lots of wires in the area which I'm not sure of thier use.
PS any one want some very average condition front audi a3 floor mats?![]()
mk2 GTi 16v
Corrado G60
I'll help you rewire the sucker when your ready. You are welcome to my vr6 airbox and the K&N thats in it if you want and if you want to run a bigger cooler on it i've got a vr4 cooler tucked away at mums place.
thats a big project! should be good fun to build thou, and it'll be hella quick when its finished.
stick it in the mk2 instead!!!
Where is the BCM located?anybody anybody?
mk2 GTi 16v
Corrado G60
