looking good mate
managed a bit more of the dissasembly process today..
crapped out shock bolts required use of the grinder + cut off wheel..
Once the rear axle was out of the way, the fully welded exhaust could then be removed from the scene...
with the gear shift linkage, steering rack all removed, it's now a bare shell...
So just converting the rotisserie drawings to metricated steel sizes, then I will fab up that contraption...
Lots of MK 1 Scirocco's...
Cheers,
Grant...
looking good mate
Well the shell is stripped free of all parts, found a few more rust issues ( mostly minor) .
Have posted on the tex for some donor sheetmetal to repair the rust and damaged locations...( have some leads already...fingers crossed.. )
getting this sorted will be the biggest job...
but pretty happy with where it's at so far..
Just found a good panel shop to Pull the 80 Storm front round for me also..( rhs of last pic..)
Cheers,
Grant...
How do you intend dealing with the rust in the "A" pillar?
What were the rims did you have on it? They looked like the Enkeis' I have on my Little Beastie.
Old Skool Passat Power Rules!!!
1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
Attempting to get some rust free parts cut from damaged US cars.. think the A pillar is the outer skin only ( 3 pieces in there)Originally Posted by brackie
Cheers,
Grant...
Originally Posted by vinderliker
had 2 x BBS RA , and the others were the standard GTI rims for the period ( 1980) same as those you were looking at but 1/2 " wider.
Cheers,
Grant...
I have just borrowed a book from the local library caled VW Golf and derivatives by John Blunnsden. It has great pics on the Scirrocco. In fact it has inspired my to track one down one day. Not being Aussie delivered (i think), how would you go about getting one?
James
What model are you after James, Mk1 or MK2.. Loon had a lead on a MK 2 in NSW somewhere..Originally Posted by vinderliker
Matty , where are the piccies mate ??
Cheers,
Grant...
There is one in Melbourne with a hit up the back. Nice car tho.
See the classifieds on here.
And there is a 1982 one in a field in Sydney that I know of.
