Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 78
Thread: Scirocco resto...
  1. #31
    Perth. WA
    managed a bit more of the dissasembly process today..
    crapped out shock bolts required use of the grinder + cut off wheel..
    Once the rear axle was out of the way, the fully welded exhaust could then be removed from the scene...
    with the gear shift linkage, steering rack all removed, it's now a bare shell...
    So just converting the rotisserie drawings to metricated steel sizes, then I will fab up that contraption...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  2. #32
    looking good mate
  3. #33
    Perth. WA
    Well the shell is stripped free of all parts, found a few more rust issues ( mostly minor) .
    Have posted on the tex for some donor sheetmetal to repair the rust and damaged locations...( have some leads already...fingers crossed.. )
    getting this sorted will be the biggest job...
    but pretty happy with where it's at so far..
    Just found a good panel shop to Pull the 80 Storm front round for me also..( rhs of last pic..)
    Cheers,
    Grant...
  4. #34
    brackie Guest
    A pillar
    How do you intend dealing with the rust in the "A" pillar?
  5. #35
    Mar 2006
    Canberra
    What were the rims did you have on it? They looked like the Enkeis' I have on my Little Beastie.
    Old Skool Passat Power Rules!!!
    1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
  6. #36
    Perth. WA
    Quote Originally Posted by brackie
    Attempting to get some rust free parts cut from damaged US cars.. think the A pillar is the outer skin only ( 3 pieces in there)
    Cheers,
    Grant...
  7. #37
    Perth. WA
    Quote Originally Posted by vinderliker
    had 2 x BBS RA , and the others were the standard GTI rims for the period ( 1980) same as those you were looking at but 1/2 " wider.
    Cheers,
    Grant...
  8. #38
    Mar 2006
    Canberra
    Question
    I have just borrowed a book from the local library caled VW Golf and derivatives by John Blunnsden. It has great pics on the Scirrocco. In fact it has inspired my to track one down one day. Not being Aussie delivered (i think), how would you go about getting one?
    James
  9. #39
    Perth. WA
    James
    What model are you after James, Mk1 or MK2.. Loon had a lead on a MK 2 in NSW somewhere..
    Matty , where are the piccies mate ??
    Cheers,
    Grant...
  10. #40
    Camden, Sydney
    There is one in Melbourne with a hit up the back. Nice car tho.
    See the classifieds on here.
    And there is a 1982 one in a field in Sydney that I know of.
Similar Threads
  1. My Scirocco Project
    By Golf Loon in forum Scirocco
    Last Post: 10-02-2011, 09:09 PM
  2. Random Scirocco in a field
    Last Post: 31-12-2009, 04:53 PM
  3. Scirocco
    Last Post: 17-02-2006, 10:57 PM
