Page 1 of 8 123 ... LastLast
Results 1 to 10 of 78
Thread: Scirocco resto...
    Perth. WA
    Scirocco resto...
    Well the time has come for one of my rocco's to be given a re birth...Managed to pick it up for $300 back in 2001...however it had to be stored up in Bindoon ( Brackie territory) for a few years..
    The weather was really starting to get to the bodywork, so it has become a necessity to git er done NOW...
    Had it trailered down early last week, then me and one of my sons began the task of stripping it down to a bare shell.
    The plan at present is to have it blasted early december ( the bare shell) still thinking about doing a caustic dip yet, may wait and see how much tin worm is residing on the underside yet...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Perth. WA
    I have some better front guards, NOS bonnet, good used doors and a decent hatch to fit from the parts collection..as pretty well all the bolt on panels have had the S**t kicked out of them...
    There is some areas of rust, the worse so far being the rear of the roof where the hatch seal lives... perforation....
    Still have'nt decided what powerplant / trans combo to fit yet, I have a few at hand...
    or ....
    Whatever goes in It needs to be easy to re register as I cant BF with all the "engineering" details for doin a high HP set up to keep it legal ..
    Cheers,
    Grant...
    looking great mate, keep us posted
    is that a 1.8T sitting there? go for the 1.8T is recon but it'd prob be more work?
    Camden, Sydney
    Got a bit of work there Grant. Might as well put a crazy motor in there if you are gonna do a full rebuild.
    The RTA have changed the rules in Sydney again, so that any engine other than the prefix that originally came with the car requires engineering. So even if you put a later 1.6 into a 1.6 Golf, you should get it engineered!
    syncro Guest
    Quote Originally Posted by Golf Loon
    If the Scirocco is a private import it doesn't matter.
    The engine pefix rule has been in for 30 years. Sometimes they stick to it and sometimes they don't.
    Camden, Sydney
    Quote Originally Posted by syncro
    I think they have tightened it up. My blue slip guy wouldn`t register one recently for that reason, so I went elsewhere and they ended up loosing their blue slip licence! May not have been my fault, but may have been
    The private import thing is interesting, My Mk2 rocco is a personal import and I wanna chuch the old 1.6 carby motor and stick in something more tasty, but I want to avoid engineering. I`m gonna do more research then.
    Sorry to hijack your thread roccodingo
    Perth. WA
    Quote Originally Posted by GoLfMan
    Yeah, needs a lot of work, but out of all the cars I have it requires the least...if u get my drift..
    Engine choices are 1.8 T aww ( 150 HP), 1.8 16 V (KR), 1.8 8v (DX) or 2.0 8v (2E)
    Trans choices are O2A, O2J, O2M ( 6 speed), O2O Close ratio or wide ratio.
    for the minute thinking the KR and either the O2A or J cable shift. Will be looking at a seqishift selector..
    got 280 front vented discs and a rear disc set up ...
    Cheers,
    Grant...
    Perth. WA
    well usually anything other than the same displacement or number of cylinders requires "engineering", but i have yet to get confirmation from the coppers here in the west.
    Cheers,
    Grant...
    syncro Guest
    How do they know what engines Sciroccos have?
    Tell them VR6s were an option.
    Camden, Sydney
    You can do that if it is a fresh import, but once it has been registered with an engine in NSW, I reckon you would have to engineer any changes.
    Or get a number stamp kit
Similar Threads
  1. My Scirocco Project
    By Golf Loon in forum Scirocco
    Last Post: 10-02-2011, 09:09 PM
  2. Random Scirocco in a field
    Last Post: 31-12-2009, 04:53 PM
  3. Scirocco
    Last Post: 17-02-2006, 10:57 PM
