In the picture that was added later, yes. The originally linked pic only showed the rotor face.
Even if you painted the rotor faces, I couldn't see the paint there surviving more than a second of braking. Of course you could have an accident in that period...
Resident grumpy old fart
I've seen people paint the friction face & rely on the brakes to remove the excess. It works but is also can contaminate the pads & smoke like crazy until it burns off.
So at least make a token attempt at masking the friction surface.
I made this dodgy cardboard screen when I did my Subaru
There was overspray but i wiped most of it off with metho.
And it does look better
Alright, thanks for the help everyone !
Last quick question, since google is giving me both answers.
When painting my calipers, do I need to prime them? Or can i just wire brush them, degrease them, dry and then spray?
One of my friends says he just cleaned them up, got the caliper paint, sprayed it into a container and painted it on with a brush. They're still going strong 1 year later too.
I just clean, wipe over with metho, mask & use a spray bomb. I don't even bother with heat resistant paint as I know I don't get my brakes hot enough to overheat / burn standard Dulux enamel
any kind of enamel paint will last very nicely on brake parts.
Even export enamel from SCA will last for years and years and years.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
That sounds awesome guys, now sorry if it's a stupid question.. but can I get the caliper paint, spray it into a lid and just use a paint brush to get the job done ? ( I don't want to remove the calipers, but i'm scared I'll get over-spray on other parts, after masking) Soz, this is just a lazy question LOL
You should watch some dyi vids on YouTube
Sent from my Nexus 5 using Tapatalk
'99 A4 Quattro 1.8T
As above
Watch DIYs
If you want to paint with a brush then save some money & buy a tin of paint.
