Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 53
Thread: Rolling with Pebbles
    Apr 2006
    Melbourne, Victoria
    After replacing the brake booster/master cylinder, the brake warning light stays on. Any suggestions on how to fix this gremlin?
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Jun 2007
    Eastern Suburbs Melbourne
    if it's the light that's near [above i tihnk?] the handbrake light, take the cables off the battery, [both] for 20-30 seconds, this discharges a capacitor that's behind there.
    Thank Andrew Robinson for that gem.
    I had the same issue a while back, i don't know what actually causes it to go off though. not a re-occouring issue for me, so i didn't worry about it.
    i like volkswagens
    Apr 2006
    Melbourne, Victoria
    Thanks Jarred I'll give it a go.
    Tomorrow me and Leah are heading down to Wilsons Prom for a couple of days. I think the car is ready........ Going to take a tool kit just in case.
    Apr 2006
    Melbourne, Victoria
    Nice one Jarred, your tip fixed it! Thanks. I also read Petes thread on boosters, im going to do that mod.
    Apr 2006
    Melbourne, Victoria
    We just returned from a three day tour of Wilsons Prom. The car drove very nicely and only had a couple of minor issues. The car seems to want to run hot. I have a manual switch for the thermo fan, and basically have it on all the time. Temp goes up if theres a hill. Should the cooling system be this sensitive? I have considered the following possible issues:
    Thermostat
    Uneven valve clearances
    blocked radiator
    Any words of advice?
    Also, the battery/alternator light is glowing dimly, like theres some demonic breakdown looming. I have checked the brushes and they seem fine. Also, i have charged the battery and the light goes out for a while (its a new battery). Could running the thermo fan all the time be flogging the battery/alternator?
    Fuel consumption was good, 33L in somewhere between 600 and 700kms. I dont know exactly as the odo stopped at 450kms but thats pretty good anyway. I have mastered the fuel efficient driving style, like a nanna in a straight line, like a maniac in the bends! So much fun!!
    Anyway, like any 30yo car, its got some problems, but we are fixing them slowly.
    Jun 2007
    i had some almost similar problems when i went up to sydney. she got warm going up some of the big hills, and still kept at about 1/2 on the temp gauge for most of the trip up.
    on the way back, temp was cooler, and seemed more powerful. i put this down to a sticky thermostat. unconfirmed if that was the issue or not.
    i like volkswagens
    Nov 2005
    it was because on the way to sydney you are actually going uphill, going back to melbourne is all downhill, hence more power and cooler temps, not as much pressure on the motor, there was times where on the way home to melb, id actually let it roll for over 5klm in N!!
    dom
    Jun 2007
    dom, i'm talking about the hills specifically, not the whole journy. there were big hills going either way. but the difference was massive.
    i went from struggling up hills foot flat, too actually accelerating up similarily large hills. Although there was about 2 hills in a row coming back that i struggled with, infact, i struggled accelerating on the flat bit after the 1st hill, and after the second, power was back and it was fine. another reason why i though sticky thermo.
    i like volkswagens
    Aug 2006
    Melbourne VIC
    I do agree Jarred had more power on the way home
    Apr 2006
    Melbourne, Victoria
    Today we replaced the alternator, no more demonic glow in the battery/alternator warning light!
    We also found some hidden ponies when we adjusted the valve clearance on no.2 inlet valve. Revs like a champ!
    Still no luck in the cooling/thermo fan department. We're on our third thermo switch now. I suspect that my configuration of the relay and thermo switch may not provide enough current draw through the switch to close the contacts. Any thoughts???
