Page 8 of 10 FirstFirst ... 678910 LastLast
Results 71 to 80 of 99
Thread: Retro spec mk1
  1. #71
    Jan 2012
    St Albans, Victoria
    Everything cooling related is new, radiator, heater core, heater tap, expansion tank, water pump, thermostat, hoses.
    Retro spec mk1-image-jpg
    I also decided to go for the larger mk2 radiator.
  2. #72
    Feb 2013
    Melbourne SE
    Nothing better than new cooling gear
  3. #73
    Jan 2012
    St Albans, Victoria
    Bosch 044 pump should take care of fuel delivery.
  4. #74
    Jan 2012
    St Albans, Victoria
    108mm bad boy
    Attached Thumbnails Attached Thumbnails Retro spec mk1-image-jpg
  5. #75
    Jan 2012
    St Albans, Victoria
    3 inch mandrel from turbo back.
  6. #76
    Jan 2012
    St Albans, Victoria
    Such a different feel to the 8v rod shift. Power delivery is soooo smooth and I get a few back fires out of the tail pipe every so often under deceleration.
    Still need to plug it into vag com to see for any faults and do a couple more test drives but overall pretty happy with the way it turned out so far.
  7. #77
    Jan 2012
    St Albans, Victoria
    New go fast bits just a little restricted with the old oem one.
  8. #78
    Nice to see progress being made. How long before you're on the road again?
  9. #79
    Jan 2012
    St Albans, Victoria
    It's been on the road for a little over a month now. Just playing around with some bolt ons.
  10. #80
    Nov 2014
    Sounds oninous...
