Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 99
Thread: Retro spec mk1
  1. #51
    Jan 2012
    St Albans, Victoria
    And the winner is................ 20vt.
    Retro spec mk1-image-jpg
  2. #52
    Jan 2013
    Perth, WA
    That will have some serious pep. Looking good mate . May have a set of those d slot steelies on mine soon, can't wait haha
  3. #53
    Jan 2012
    St Albans, Victoria
    Quote Originally Posted by mk1ster View Post
    Cheers,
    it's only bolted up to the car ATM, needs fuel system done, cooling, wiring and the list goes on.
    But a fun little project.
  4. #54
    Feb 2013
    Melbourne SE
    Looks the goods, but running is better!
  5. #55
    Aug 2006
    Melbourne VIC
    Wow!!!!!
  6. #56
    Jan 2012
    St Albans, Victoria
    Hopefully in the next coupe of weeks i can at least get it running. Because of the complete engine and 02j conversion I've got a few miner set backs on the gearbox side that's obviously not a direct fit like speedo, clutch cable and reverse switch.
  7. #57
    Feb 2013
    Melbourne SE
    After the gearbox, what else is needed? Surely you can just wire up to the reverse switch with your existing wires.
  8. #58
    Jan 2012
    St Albans, Victoria
    It is just that simple Jordan.
    But 02j gearboxes usually run a hydraulic clutch slave and Due to the fact it's going in a mk1 I don't really want to stuff around converting the car to suit this set up....only just for now.
    I will be using a a cable operated one that's from a seat. Doing this doesn't allow me to run a reverse switch at all. So I'm going to try and come up with something to fit.
    I also need to run the cable operated shifter which I excited about.
    Basically in a nut shell I just would like to get everything working the way it should before I start diving, because I know I'll leave it on the back burner.
  9. #59
    Feb 2013
    Melbourne SE
    Quote Originally Posted by Petska84 View Post
    I spot stock brake booster and mc...
    Is this still running stock brakes? May want to look into upgrading that if you want her to stop as hard as she'll go Retro spec mk1
  10. #60
    Jan 2012
    St Albans, Victoria
    Hahaha, I'll be upgrading that also with larger breaks on the front and disks on the rear.
    Only cruising to the local Bowles club on the weekend Jordan.
