Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 99
Thread: Retro spec mk1
  1. #41
    Jan 2012
    St Albans, Victoria
    Some more pics of the weekend
    Retro spec mk1-image-jpg
  2. #42
    Jan 2012
    St Albans, Victoria
    The blow up and recovery
  3. #43
    Ahhhhh, having to be rescued by mates with a trailer, brings back so many memories.
    Congrats on getting 1st place, well deserved in my opinion and on getting back home (eventually). Great to hear that George helped out so much. I bet you don't get that with modern car owners.
    What are you looking at to replace the 1.6?
  4. #44
    Jan 2012
    St Albans, Victoria
    Most likely a 1.8?
  5. #45
    1.8 is a nice step up from the 1.6. Intersections that you used to change down into 2nd can be taken in 3rd and hills don't affect the car.
    2.0 is much more fun though. A big improvement in performance and it's still pretty easy to fit into the MK1. The 2.0 in my MK2 has a 2.0 bottom end with the original MK2 GTI head and it's really fun to drive. Not so powerful that it attracts Police attention but quick enough to overtake without worrying about oncoming traffic.
    Paul
  6. #46
    Gosford Central Coast NSW
    Yeah if you go 1.8, a bit higher compression ratio is really nice. All the 2.0l engines have reasonable compression ratios anyway because they are from the 90's, but some of the 1.8's aren't that peppy.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  7. #47
    Jan 2012
    St Albans, Victoria
    Found out why the motor gave way.
    The sump plug must of come loose on the hwy and no I never done a oil change on this engine,but yes I should have checked.
    Doesn't help that the oil psi warning light came on after the motor failed.
  8. #48
    Jan 2012
    St Albans, Victoria
    It's out.....
    .Retro spec mk1-image-jpg
  9. #49
    Aug 2006
    Melbourne VIC
    Just fill it back up with oil yeah?
  10. #50
    Jan 2012
    St Albans, Victoria
    Quote Originally Posted by Water Boy View Post
    The damage has been done dude, it had a bottom end knock before it conked out. Suspected thrown bearing at the least.
