Results 1 to 10 of 78
Thread: The Red Thread
Peter Jones The Red Thread 25-05-2009, 08:22 PM
Peter Jones Over the weekend I replaced... 25-05-2009, 08:28 PM
GoLfMan good to see Red finally... 25-05-2009, 08:33 PM
greasykitchen That ain't just any horn,... 25-05-2009, 08:40 PM
16v_kid nice work pete! 25-05-2009, 10:32 PM
Peter Jones New dash for red today. ... 14-06-2009, 06:23 PM
Tim I just had a look at the king... 14-06-2009, 06:46 PM
Peter Jones Well that explains a lot!... 14-06-2009, 06:54 PM
Peter Jones Can't see the numbers on the... 14-06-2009, 07:03 PM
cab93 Both mounts are stuffed! ... 14-06-2009, 10:05 PM
Spyda I thought it was to do with... 14-06-2009, 11:06 PM
roccodingo 5 mm is quite normal, its... 15-06-2009, 01:03 AM
Peter Jones Red got new seats today. ... 25-07-2009, 01:56 PM
gldgti oh, now that looks nice.... 26-07-2009, 08:03 AM
Mrk_Mickey Tis naice, those bolsters... 26-07-2009, 10:30 AM
roccodingo So you swapped the base to... 26-07-2009, 09:13 PM
Peter Jones Red got some attention today,... 03-01-2014, 08:44 PM
Peter Jones Words and pics by Jodie. I... 22-02-2014, 09:19 PM
golfmeup Top stuff! I'm sure it must... 23-02-2014, 10:19 PM
Peter Jones Red's Toyos have finally worn... 17-03-2014, 02:47 PM
Peter Jones Red's engine is getting... 01-01-2015, 09:23 PM
Peter Jones Work on Red continues, even... 02-01-2015, 07:54 PM
morgs I gave up working on my car... 02-01-2015, 09:02 PM
Peter Jones He probably did, those tyres... 02-01-2015, 09:09 PM
dubstar Hi Pete, can you take a close... 05-01-2015, 01:26 PM
Peter Jones Dusted off a spare motor I... 17-01-2015, 07:39 PM
gldgti Only you could be so deadpan... 17-01-2015, 07:56 PM
Peter Jones Haha.:rolleyes: Took me... 17-01-2015, 08:42 PM
Peter Jones The gearshift hit the... 17-01-2015, 08:57 PM
abreut Good work, another ABF mk1 is... 18-01-2015, 08:37 AM
Peter Jones Things have changed recently.... 18-01-2015, 03:06 PM
Petska84 Love your work Pete..... Is... 19-01-2015, 02:10 PM
Peter Jones Yep, being a stock ABF it's... 19-01-2015, 05:49 PM
Peter Jones Red decided a couple of weeks... 12-09-2015, 08:01 PM
gldgti Glad I'm not the only person... 13-09-2015, 07:45 AM
Peter Jones It was pressurising the... 13-09-2015, 08:36 AM
gldgti Sounds like a bad compression... 13-09-2015, 01:48 PM
Peter Jones Start with this ... 13-09-2015, 07:11 PM
Peter Jones Timing belt received,... 20-09-2015, 08:19 PM
sports racer How user-friendly is it to... 25-09-2015, 01:44 PM
abreut I really think you have been... 03-10-2015, 05:22 PM
Peter Jones That's just silly. The ABF... 03-10-2015, 07:25 AM
sports racer Thanks guys for that info.... 04-10-2015, 01:56 AM
Peter Jones Made a heat shield to go over... 04-10-2015, 08:54 PM
    Jun 2007
    Country Victoria
    I take it the mounts are considered worn, when the gap between the rubber and metal top piece gets to large? I have replaced mine, yet there is already a gap of approximately 5mm. Would you know if this means some other part is faulty?
    Love your plastic mount covers very rare! Should you come across one or two spares, I would be happy to purchase.
    The dash looks brilliant, well worth the effort!
    Michael
    Feb 2007
    Quote Originally Posted by cab93 View Post
    Michael
    I thought it was to do with cracks and the softness of the rubber?
    MK1 GLS 3door
    A4 B7 2.0T
    Perth. WA
    5 mm is quite normal, its when they get to 10 ++ they start transmitting the full load thru to the towers.
    These things are only good for around 15000 miles max from what the yanks tell me, Be aware there are several differing brands also, quality will vary.
    Note paint cracking around the inner raised section of the body adjacent to the mount , good telltale as well !
    I have looked into converting the Mk 2 mounts into a Mk 1 as well, work in progress
    Michael
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Oakleigh VIC
    These are from an Audi 90 I think. Bit of modification of the MK1 base required to swap the base upholstery over but the back just bolted into place. Even the hinge covers went back in properly. All worked out very neatly.
    I swapped the tin base from the Audi seat into the MK 1 base as the cusion was a fair bit deeper than the MK1.
    Here's the new hybrid base next to a normal MK1 base (right)
    One seat in
    The freshly welded and painted hybrid base.
    Reattaching the base fabric and cushion.
    Both seats in now
    A lot firmer and a little higher than the old seats. Very comfy.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Gosford Central Coast NSW
    oh, now that looks nice. could almost be the inside of an audi...
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Dec 2007
    Ermington, Sydney
    Tis naice, those bolsters even look half decent!
    Perth. WA
    So you swapped the base to gain height or the old ones were damaged ??
    I have 4 Scirocco 1 seat bases here with the height udjustable mechanism that will slide straigt into a Mk 1 , just need to do what you did and swap the foam and upholstery over .
    Still looks impressive result tho Pete.
    Cheers,
    Grant...
    Oakleigh VIC
    Quote Originally Posted by roccodingo View Post
    The spacing between the back legs on the later model seats (MK3, cordoba, Audi etc) is different, they're much wider apart. The lever mechanism for the locking pin is on the wrong side of the centre rail too.
    I used the MK1 frame because it fits into the rails correctly. I unpicked the tin from the Audi seat and put it into the MK1 base because the late model cushion foam is a different shape on the underneath and doesn't sit right in the MK1 tin. It sort of sits on top of the tin and the sides of the cushion don't get supported properly.
    So I suppose in answer to your question, the end result was to actually lower the seat cushion compared to if I had used the MK1 tin.
    It's a bit hard to explain unless you see it, hope that makes it clearer.
    Those scirocco frames sound like a nice thing.
    Pete
    7? MK1 Caddy
    12 Amarok
