Haha.
Took me about 5-6 days all up. There's a few more challenges than I'd realised and there was a lot of stuff on Red I'd always meant to get around to that this conversion made unavoidable.
I did have an Ashley extractor set I was planning to use but it didn't fit because the ABF is so tall. I ended up using the stock exhaust manifold and fabricating my own down pipe.
40mm Dellortos are off white.
I customised a new set of 16v leads to go into a rebuilt Saab dizzy.
The Saab dizzy is hall effect so I also had to set up and wire in the same Bosch ignitor and coil as the late MK1s.
Bit of faffing about to move the brake fluid reservoir sideways a bit to clear the dizzy and I had to relocate one of the brake lines into a T piece to make it all fit.
Also fitted an air/oil cooler and deleted the water/oil cooler system.
Here's the exhaust work
