Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 78
Thread: The Red Thread
  1. #61
    Gosford Central Coast NSW
    Only you could be so deadpan and awesome at the same time pete
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  2. #62
    Boronia VIC
    Haha.
    Took me about 5-6 days all up. There's a few more challenges than I'd realised and there was a lot of stuff on Red I'd always meant to get around to that this conversion made unavoidable.
    I did have an Ashley extractor set I was planning to use but it didn't fit because the ABF is so tall. I ended up using the stock exhaust manifold and fabricating my own down pipe.
    40mm Dellortos are off white.
    I customised a new set of 16v leads to go into a rebuilt Saab dizzy.
    The Saab dizzy is hall effect so I also had to set up and wire in the same Bosch ignitor and coil as the late MK1s.
    Bit of faffing about to move the brake fluid reservoir sideways a bit to clear the dizzy and I had to relocate one of the brake lines into a T piece to make it all fit.
    Also fitted an air/oil cooler and deleted the water/oil cooler system.
    Here's the exhaust work
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  3. #63
    Boronia VIC
    The gearshift hit the downpipe so I had to straighten one out a bit in the press.
    I had to make this tiny throttle cable clamp on the lathe. I made it from a brass tap handle that I'd removed when I renovated my bathroom.
    Relocated the brake fluid reservoir with plumbing fittings. I copied the barbs that go into the master cylinder in brass and sweated the copper bends together.
    It'll do until I figure out a more elegant way of doing it.
    Ebay oil cooler and lines.
    Just a reducing fitting I had to make to join some of the heater hoses. Bit of chatter on the lathe but it'll just add a bit of texture for the hose to grip.
    7? MK1 Caddy
    12 Amarok
  4. #64
    Jan 2006
    Good work, another ABF mk1 is born. Are you allowed to go up to 2l in a mk1 without engineering in Vic? We can only go up to 1.9l in NSW.
  5. #65
    Boronia VIC
    Things have changed recently. If you increase power by more that 20% you need VASS sign off. It's no longer purely capacity based.
    The most powerful motor fitted stock to a mk1 was an 1800 at 91Kw, the ABF stock has 110Kw which is about a 20% increase so it might scrape through on a technicality otherwise it'll need VASS sign off.
    7? MK1 Caddy
    12 Amarok
  6. #66
    Jan 2012
    St Albans, Victoria
    Love your work Pete..... Is it still going to be a daily?
  7. #67
    Boronia VIC
    Yep, being a stock ABF it's quite nice to drive, very tractable.
    I've got some smaller venturis for the Dellortos which I might put in there later on.
    Plenty of low down torque which suits the tall gearbox that's in there.
    I think I'll have to sort out a better air cleaner arrangement too.
    It's all pretty tight in there.
    7? MK1 Caddy
    12 Amarok
  8. #68
    Boronia VIC
    Red decided a couple of weeks back that he preferred his engine oil all over the driveway. So we took off the head and sent it away for refurbishing. Looks like this engine's never been apart before.
    All shiny and sorted! No major issues with it, just needed refreshing.
    Bottom end needed refreshing too.
    Took these out.
    Got one of these.
    Gave the barrels a honing.
    All clean and smooth again.
    New rings from Japan!
    New bearings from Brazil!
    One of these.
    And back they go.
    That's it so far, dinner time was calling.
    7? MK1 Caddy
    12 Amarok
  9. #69
    Glad I'm not the only person that's been rebuilding engines lately.
    Why did it drop its oil?
    Sent from my Nexus 5 using Tapatalk
    '99 A4 Quattro 1.8T
  10. #70
    Boronia VIC
    It was pressurising the crankcase big time.
    I can only put it down to blowby or perhaps the very worn exhaust guides.
    Once above idle speeds it was pumping oil out the filler cap continuously. Very odd behavior.
    Crankcase breather wasn't blocked and all the drains from the head to the sump were OK too.
    Engine was in great shape when I pulled it down.
    Compression readings were all over the place though. Head work and rings will see it sorted though.
    I'm going to add another breather to it too just in case by using a new beetle oil filler breather setup.
    7? MK1 Caddy
    12 Amarok
