Page 8 of 8 FirstFirst ... 678
Results 71 to 78 of 78
Thread: The Red Thread
  1. #71
    Gosford Central Coast NSW
    Sounds like a bad compression leak... If the crankcase was pressurised enough, the oil will have trouble getting back down the drains from the head.
    Sent from my Nexus 5 using Tapatalk
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  2. #72
    Oakleigh VIC
    Start with this
    Add some stuff
    Replace thermostat
    Needs moar shiny
    Realise timing belt is wrong one. Swear. Order new one. Clean up and wait for delivery.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  3. #73
    Oakleigh VIC
    Timing belt received, everything screwed back together
    Just to prevent any more oil leaks from the cap.
    Catch can's not moving anytime soon.
    After sitting around for a few weeks, Red was covered in dust and overdue a bath.
    Clean Bunny.
    7? MK1 Caddy
    12 Amarok
  4. #74
    How user-friendly is it to drive in traffic?
    The stories I've been hearing is the ABF needs lots of revs and doesn't have much torque down low which has pushed me towards fitting a 9a into mine (with ABF head). I've got an ABF as well so it would be good to get your opinion.
    Paul
  5. #75
    Oakleigh VIC
    That's just silly. The ABF has heaps of torque. This one used to push a much heavier Toledo around just fine.
    There's been no issues in the MK1, This is a 2.0L motor after all.
    Even with the twin Dellortos it'll take off from the lights at idle speed.
    7? MK1 Caddy
    12 Amarok
  6. #76
    Jan 2006
    Paul
    I really think you have been misadvised about the ABF. I recall you mentioning this before.
    I too drove my ABF in the Toledo it came from and it was a really solid motor with plenty of torque in that heavy car. I was quite impressed. Actually the owner of that totally stock Toledo on street tyres did a high 1:18 around wakefield! I really doubt that a 9a can outperform the ABF stock vs stock in virtually any way. Why would VW go backwards? Besides, the tall block config is superior – better rod ratio, and less chance of piston slap.
    Saying that I have been in a few cupras where the ABF was definitely not running right, and seemed to be all sound no go. Maybe that is where these stories come from.
  7. #77
    Thanks guys for that info. One of the guys here in Canberra had one in his MK1 and swears he'd never do it again because it was a pig in traffic.
    I'll take a 2nd look at the ABF block I've got and see if I can get away with honing or if it needs a rebore.
  8. #78
    Oakleigh VIC
    Made a heat shield to go over the exhaust manifold today.
    I had tried to use the cast ABF one but couldn't stop it from rattling. It kept setting up a weird harmonic and would buzz away at certain RPM.
    We'll see how this one goes.
    7? MK1 Caddy
    12 Amarok
