Battery
Rear light loom running along the chassis. Didn't have to really hide this, but we mounted it with copper saddles to keep the theme
Note all the chassis work, 4 link setup & airbag setup/
Rear lights
Pedal's! Peterbuilt truck accelerator pedal as the brake! haha
The old saying "Ken thought it was worth it, so Peter built it!" haha
The copper piping & valve is the airbag dump pipe! It doesn't have enough room to run a airbag tank & just runs off the compressor through a check valve/one way valve. So the pump isn't under constant pressure all the time.
You can just see the open pipe where the dump exits!
Fuel lines
Nice little touch is the olds rocker cover /spark plug trims! I like them & space the ignition leads nicely out too!
Carb's on adapter plate!
