Results 1 to 9 of 9
Thread: R32 brake conversion on Bora V6 4Motion
    Apr 2008
    Hi all,
    I've got the R32 calipers and rotors. Do I also need the R32 carriers?
    Cheers!
    Nothing to see here...
    Oct 2006
    sydney
    yep you do the bad news is if you dont have them they cost 300 more from vw new
    Oct 2006
    sydney
    i have a full set up for 1k if you want them due to the fact i cant find wheels i want
    ireland
    Personally i wouldn't bother with the R32 set far too heavy,if you are going for serious power and need brakes to match then go for a leon cupra R set up or some nice porsche stoppers.
    VF Stage1 Supercharged V6 4motion Bora
    Apr 2008
    I already have the calipers and rotors - will need to check if the carriers are attached. The comment on weight is absolutely right -they're hideously heavy. Not only that, they're hideously expensive too - $580 each from VW in Australia at trade prices...
    On the carries, for a change VW in Australia may be comparably priced to overseas - ECS want USD$213 each for them.
    William: What wheels are you after?
    Apr 2008
    Good news - I appear to already have the carriers (I thought they were a separate item to what I have, but they're actually part of the assembly I've been referring to as the caliper.
    w00t!
    Apr 2008
    Further to this - apparently I need the longer R32 brake lines - rather than going for OEM rubber ones, I'm looking for ADR-certified braided lines. Are there any local manufacturers I should look at?
    Mar 2010
    auckland NZ
    The thing being with the R32 carriers is that they "correct" your front arm geometry for a lowered car as the spindle height is different, my Jetta 4 motion had lowered springs and the front arms were at quite a big upward angle really affecting the handling.
    I installed R32 struts, uprights, driveshafts and arms to "correct" everything, amazing difference!
    May 2007
    Moonee Ponds
    yuppe for me already have r32 stock springs and dampers
    Audi B4 80 Q V6 '94 Race Car !! KEGGED
    Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo '01 Gone
