Results 1 to 9 of 9
Thread: Projekt Audi
    Mar 2009
    Projekt Audi
    As some of you may know my beloved R32 met a tragic end a couple of months ago and while I still do miss the car, I now have a new toy to keep me occupied for a little while!! This car most of you will know is Alex G's old Audi A3...
    His 50+ page thread can be seen here;
    the i promise to keep it standard A3
    The car itself is a 1999 Audi A3 3dr hatch, sporting a 20v 1.8t which has just tipped over 91,000km! Quite low km's considering its vintage!!
    The modifications I've listed below are what I can think of just off the top of my head, I'm sure I've missed quite a few additional changes. The A3 did sport a custom set of AME Fire wheels which were unfortunately stolen not long after getting the car all the way back from Sydney.
    EXISTING MODIFICATIONS
    ENGINE + PERFORMANCE
    - Custom FMIC setup
    - Custom twintake
    - Oettinger spec'd K04 turbo
    - Forge BOV
    - Larger injectors
    - Custom Intake Manifold
    - Relocated TB
    - Custom hardlines
    - Custom Catch can
    - CustomCode tune (still on base)
    - 3in turboback exhaust
    - Lightened pulleys
    - Larger fuel pump
    - Relocated battery to boot (drycell)
    EXTERIOR
    - Stubby aerial
    - Rear wiper delete
    - Modified front bar
    - Aftermarket headlamps
    - Clear side indicators
    DRIVETRAIN
    - Dieselgeek 5sp shifter
    - Spec Performance Stage 3 clutch
    - Billet single mass flywheel
    INTERIOR
    - Parrot headunit
    BRAKING
    -ECStuning Stage 1 upgrade (330mm front discs)
    -EBC greenstuff pads (F)
    WHEEL + SUSPENSION
    - Raceland coilovers
    - DLI Engine mounts (passenger & drivers side)
    - BFI dogbone bushings
    - Audi TT Mk1 wheels
    Over the past month I've managed to do the following;
    CURRENT MODIFICATIONS & MAINTENANCE
    EXTERIOR
    - Refit stock door mirrors
    - Replaced number plate bulbs with LEDs
    - Upper brake light bulbs replaced
    - New wiper arms & blades
    DRIVETRAIN
    - CV boots replaced (died day after I got back from Sydney Doh!!!)
    INTERIOR
    - Replaced interior bulbs with LEDs
    BRAKING
    - Replaced front brake hoses and performed fluid flush
    WHEEL + SUSPENSION
    - Fitted C-Pillar brace from R32
    - Removed rear camber shims
    CURRENTLY ON ORDER/TO BE FITTED
    - N75j Boost Solenoid
    EXTERIOR
    - ZIZA H7 headlight bulbs
    INTERIOR
    - New shiftboot & knob
    - Podi Mechanical boost gauge
    WHEEL + SUSPENSION
    - Whiteline FSB & adjustable endlinks
    The car is currently running on a CustomCode base tune, logging for the final tune should commence next week and should hopefully be finished before Christmas!! From initial driving, we thought that the car was boost spiking but after setting up the logging equipment and doing some tests on both the wastegate actuator & N75 boost solenoid, we realised that the Stack boost gauge is out of calibration. I decided to order a Podi mechanical boost gauge which will match perfectly to the existing cluster lighting.
    So where to from here;
    TO DO
    - Fit oil cooler
    - Fit custom fab'd coolant reservoir
    EXTERIOR
    - Replace front 1/4 panels
    - Replace bonnet
    - Replace front bar
    - Sort surface roof rust
    - Remove bootlid spoiler & fit S3 roof spolier
    - Re-align passenger side door
    - General paintwork clean up
    - Tint
    INTERIOR
    - 20th Ed Gti overhead light (black)
    - Refurb roof lining and door trims (if can be bothered)
    - Refurb seats (if can be bothered)
    - Remove rear seats and box up
    BRAKING
    - Replace rear discs with DBA slotted
    - Change out pads for QFM pads all round
    WHEEL + SUSPENSION
    - Whiteline RSB
    - Swap out Raceland coils for KW V1s
    - Refurb Audi TT wheels & add spacers (short term)
    - New wheels (long term)
    Finally a few pics which I've shamefully pinched out of Alex's thread since I haven't had a chance to get out and take some decent pictures of the car other than the couple of phone pics at the bottom.
    Getting a well deserved claybar & polish
    Gav continuing his magic
    Cheers!
    Jun 2009
    Madness, it is such a quality car!
    Hope you enjoy it as much as the .:R
    No AWD though?
    Jul 2009
    Geelong, Victoria
    looks great.
    Those brakes are massive!
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Sep 2006
    Australia?
    I don't know why you would do this though:
    - Fit custom fab'd coolant reservoir????
    I would leave it the way it is, looks a lot neater and the resevoir does f-all!
    sydney
    To quote buzz lightyear "to infinity and beyond"
    Looking forward to it new incarnation.
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    Was sad to see this come up for sale.
    Had my juices flowing at Nats11!
    But great to see its back on the forum and has some nice plans for it!
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jun 2009
    Are you brining it to Happy Laps next Saturday Corey?
    Mar 2009
    Quote Originally Posted by team_v View Post
    No AWD though?
    I'm sure I will mate!! Just need to get a couple of bits sorted, doesn't help when you're a fussy prick! HAHA.. Not to sure if I'll be at the happy laps, definitely won't be running the car though...
    Quote Originally Posted by DubSteve View Post
    Piece of mind?? Not worthwhile to add extra to the system along with having a bit more room for air bubbles?? The reservoir would be mounted onto the radiator support and sprayed black. The really ****y looking part would be the housing I guess.. Food for thought I guess.
    Quote Originally Posted by alex g View Post
    Thanks mate
    ---------- Post added 07-12-2011 at 12:55 PM ---------- Previous post was 01-12-2011 at 04:40 PM ----------
    Quick snap, thanks to DrewR
    Mar 2008
    Nice shot, I think I saw a few from the JDMST meet too.
