Results 31 to 39 of 39
Thread: Project Turbodiesel
  1. #31
    Apr 2006
    Melbourne, Victoria
    Just cos i didnt plan for high performance doesnt mean that i wont try for it. I guess that i know myself!
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
  2. #32
    Apr 2006
    Melbourne, Victoria
    A quick update on the project, the motor is home from the engine builder. It has the oil squirters installed. I have an intercooler from a saab, and a massive radiator from and Audi. Today I marked the toledo flywheel with a TDC mark and should have the motor and gearbox in this week! On the way from Canada I have a TD air filter assembly, CCV system and injector lines. All I need now is a k14 downpipe and exhaust.
    Photos to come.....
  3. #33
    Hey Matt.
    Thought I'd add this on here for reference sake & hopefully someone out there can also add some info.
    I found the engine codes for the diesel engines in the US Spec caddy's for you
    JK - 1985-90
    ME - 1990-92
    Rod bolt # 037 105 425
    Rod nut # 068 105 427
    This is the bit of info I'm not 100% on though sorry Matt.
    The tightening torque of the conrod nuts (the conrod's have pressed in rod bolts & then the nuts are tightened as below)
    33 ft lbs - NA form for the engine code above.
    For the turbo'd diesel (AAZ) They are conrod bolts
    depending on chassis # or bolt size
    028 105 425G M8x1x42
    028 105 425C M8x1x45
    22 ft lbs +1/4 turn is - FI/Turbo (stretch bolts)
  4. #34
    Apr 2006
    Melbourne, Victoria
    Fitted 2.5" mandrel bent exhaust and tidied up engine bay. It wont be long now and there will be white smoke at the front, black at the back!
  5. #35
    Apr 2006
    Melbourne, Victoria
    Donor motor, 1.6D
    Long motor ready
    Engine build bits inc turbo pistons, valves and oil pump
    Thermal/friction coated pistons
    Motor is in!
    Cylinder head with new seats and guides
    mild porting
  6. #36
    Sydney NSW
    WOW nice work!!! I admire your bravery!!
    hope you get a great sense of satisfaction at the end of this one
  7. #37
    Apr 2006
    Melbourne, Victoria
    Coated pistons
    Block to be honed
    Engine bay bits
    Oil squirters installed in the block
  8. #38
    Jun 2007
    Eastern Suburbs Melbourne
    good work, glad to see it's coming together!
    i like volkswagens
  9. #39
    Camden, Sydney
    Looking Good Mate. Nice to see a build thread with some action and pics.
    Keep the updates coming.
